Runflats.... other that expensive to replace what are the negatives. I realize not everyone likes them. I've had them since 2006 and swear by them. It's a good feeling knowing I'll most likely make it home if air is lost. Not trying to start a debate or argument. Just interested in the negative side of Runflats if there are any. Thanks.
My F10 535i came with Goodyear LS2's, which have a reputation of being the worst RFT's around. Also, I practice "tire whispering," where I systematically adjust the tire pressures to achieve even tire wear. With the LS2's, that meant maintaining the pressures at about 15% over what the door jamb decal recommended. Here was my tread depth at 30k miles. After adjusting my tire pressures for optimal, even tread wear,
the ride was bone-jarring and the
performance of the tires was greatly diminished. Even with the drastic over-pressurization, I wasn't able to achieve perfectly even wear across the tires.
The inherent problem with RFT's is that the rigid sidewalls that prevent a tire from collapsing when deflated also prevent the sidewalls from stretching in the circumferential direction. Circumferential stretching of the sidewall is what makes radial-ply tires superior to bias-ply tires.
The cords in tires (nylon, rayon, aramide) resist stretching. Bias-ply tires have cords in multiple directions within the sidewall, preventing the sidewall from stretching in multiple directions. The breakthrough with radial tires was that the cords are only it in the radial direction. This allows the rubber in the sidewalls, in between the cords, to stretch in the circumferential direction (90 degrees from the radial direction). That sidewall stretching allows for the tread of the tires to conform to the flat road surface. This evens out wear on the tread, and improves traction, durability, and fuel economy.
With a bias-ply tire or an RFT (which has radial cords) the sidewalls have a limited ability to stretch in the circumferential direction. This causes the tread area contacting the pavement to buckle inward, concentrating the weight around the edges of the contact patch. That constant buckling and unbuckling as the tire rolls along also causes the edges of the contact patch to squirm against the pavement. The increased weight and squirming causes increased wear, particularly on the inner and outer edge of the tread. The best analogy is a deflated basketball or soccer ball. The deflated ball doesn't get a flat spot. The total surface area of the ball remains constant, so a depression causes a concave dimple instead of a flat spot.
That circumferential stretching of the sidewalls in radial tires is what causes radial tires to bulge out at the bottom, even when properly inflated.
The breakthrough in RFT's will come when somebody develops a sidewall which will easily stretch in the circumferential direction, but will not collapse in the radial direction.
I refused to buy (or lease) another BMW without a spare tire and a hole under the trunk or cargo compartment floor to put it in. We passed on getting a E84 X1, a F25 X3, or an F15 X5 40e for these reasons. I had to add "or lease" because I wouldn't own a X5 40e (hybrid). But, BMW was offering crazy lease deals on them.
The G01 30i offers not only a spare tire (option code 300, not to be confused with color code 300 (Alpine White III)) for a mere $150, but it also offers non-RFT, 19" all-season tires as a no cost option (option code 25X). With the non-RFT's, BMW throws in the spare for free!
In contrast to the LS2's, the non-RFT Bridgestone Dueler Sport A/S's on Frau Putzer's X3 are wearing evenly with only about the pressure only at about 5% over what is recommended on the door jamb decal. Based on the treadwear at 8k miles, the OE tires should last to around 55k miles.
Replacing the LS2's on my 535i with non-RFT Michelin Pilot Super Sports (PSS's) absolutely transformed the car. Leaving the dealership, driving over the less than one-inch drop between the driveway and the gutter of the street, the ride was so much better that I stopped and checked the tire pressures before my 95 mile drive home.
