I know there are numerous posts on the subject of "DSC-ABS-Brake lights on", but I am concerned that the problem is bigger/smaller now that I have done some of the recommended remedies. I have not done them all, but wanted to get some input before I swipe my credit card again.
I won't bore you with a long discussion on what you already know...
So far I have...
Reason for asking for help before changing rear sensor...
I am not an idiot. I have read on this and other forums that in order for the problem to be a rear sensor I would have to have lost functionality of one the items above. I have already ordered a rear sensor to install, but wanted other opinions before installing.
After installing the rebuilt ABS module (original to my car; did not need to be coded), the fault code went away, but the lights remained.
After installing the front-passenger ABS sensor the DSC light remained, but the Brake and ABS lights went away for about .5 mile and then returned. I thought the lights went off briefly, simply because I disconnected the sensor today and it sort of reset itself, but I have disconnected it before since installing the ABS module, and they have never turned off; even after unhooking the battery for hours, these lights always stay on. Also, before putting the wheels back on I connected the new sensor to drivers-side, reconnected the old sensor to the passenger-side and the lights remained on, as they usually do. So, I thought I must have the correct sensor, or at least one of them.
Questions...
Thanks in advance for your help. Feel free to point me to a post or thread that has the information.
- DSC-ABS-Brake lights stay on
- Full functionality of speedometer, odometer and cruise control
- P0500 fault code - front and rear, passenger side abs sensors bad (when codes were read it said right front and rear; is this the same as passenger side)
So far I have...
- Rebuilt ABS module
- Changed front, passenger-side ABS sensor
Questions...
- Am I all wrong about the rear ABS sensors and what they control?
- Should I just change all sensors and go from there?
- Is it possible that the problem is more than just the ABS sensors and ABS module? (I've read that the front wheel bearings could be an issue.)
- Why did the DSC light remain when the others went out, albeit for a short period?
- Is there a particular sensor that is specific to the DSC?
- Is this truly just a stealership item?
- Am I really an idiot, who's to stubborn to shell out the cash?
