bmw e39 check coolant level
3.1K views 7 replies 4 participants last post by  Banin
#1 ·
Hey guys. I keep getting the message check coolant level. The car temperature is very normal, but the engine is very hot even after some time the car has been off. I check the coolants level and the sensor is in there max position. Today I took a look at the engine and saw the coolant everywhere splashed by the fan. Also notices a small crack on a part that I do not know the name of. Here are the pictures. Question is what's the name of this part and can this be the only problem?
Your help is much appreciated.
#6 · (Edited)
thats a bleeder... and part of the hose (on your 6cylnder)
but yeld to these words.. your in trouble
has nothing to do with milage.. in your case.. the parts are old and orginal..
your going to get cought out there and when you do, if your lucky you wont need a engine when its all done
#7 · (Edited)
is that bleeder on the radiator coolant overflow tank? i can't tell from the photo. but i do see in one of the photos that there's traces of coolant all over the side of your radiator coolant overflow tank, like it was pouring out of that. is there a crack on that anywhere? you'll have to replace that overflow tank if you find any crack; it's not expensive at all. but you have to do it very soon. to replace it is also not hard.
others more knowledgeable will chime in.
good luck!
