...The O2 sensor I changed IS the one with the longer grey sheathed cable for Bank 2 sensor 2 in the position in the exhaust pipes (I accessed the sensor for removal from under the car).....the Bosch part # 17102 matches what was installed in that position. Don't understand what you mean. Bank 2 Sensor 2 should be the SHORTEST cable (490mm) of any of the four. When you say "O2 sensor I changed" do you mean the new one or the old one? When you say Bosch #17102 matches what was installed" do you mean that was the part there BEFORE you replaced, and if so, how did you identify part# -- was that legible on the old part? If so, that was the wrong part to begin with.
Is it possible that P2272 actually designates the O2 sensor in the position closer to the head/engine for the rear 3 cylinders (4, 5, 6) rather than the sensor in the position that I swapped out with the new sensor? NO, not if I understand your question correctly. P2272 relates to the POST-cat Bank 2, or REARMOST O2 sensor of the four (that is why it has the shortest cable, as ALL cables run to the rear or center, rather than to the front (see explanation below); that P2272 code relates to the rearmost sensor (#2) on the rearmost exhaust manifold (Bank 2, cylinders 4 - 6)
I will try swapping the sensors for Bank 2 (both with the longer cables - 1 has a gray sheath and the other has a black sheath) and see if the code moves to Bank 1 sensor 2. The POST-cat O2 sensors BOTH SHOULD have SHORTER cables, 490mm & 560mm respectively, as compared to the PRE-cat O2 sensors which have 1200 & 1400 mm cables
Hi Todd,
We may be misunderstanding each other. Please refer again to the Autohaus link I provided earlier:
https://www.autohausaz.com/catalog/...g/c/bmw/2007/1440982-335xi_e90/19-emission_system/5132-oxygen_sensor?s=d&page=1
Bank 1 is the FRONT three cylinders (closest to the front bumper), cylinders 1 - 3. Bank 2 is the REAR three cylinders, cylinders 4 - 6. Since the O2 sensor cables run to connectors BEHIND the engine, the sensors that are positioned most forward (the Pre-cat sensors) have the LONGEST cables.
Likewise, the Post-cat sensors, located farther rearward in the vehicle, have cables that run rearward, or inboard, so their cables are SHORTER. So if you had the correct Post-cat O2 sensors (that codes P2272 & P2271 pertain to) installed, they would have cables that were 490mm for Bank 2 Sensor 2 (part #16796) and 560mm for Bank 1 Sensor 2 (part #16413).
You can't tell the players without a program -- so here is the program, the TIS schematic for the O2 sensors on your 335xi that I linked in my first post to this thread:
https://www.newtis.info/tisv2/a/en/...ntrol-valve-msv/exhaust-emission-system/oxygen-sensor-emissions-control/x5UZsdI
TIS schematics are interactive, which means that if you click on any of the BLUE component ID#s, you get a list of other information related to that component. Doing this with the Schematic linked above gives the following "Installation Location" for the two Post-cat sensors:
https://www.newtis.info/tisv2/a/en/e90-335xi-lim/SBFyvYR
Finally, here is the Installation Location for the Connector (X62202) that the subject sensor cable connects to:
https://www.newtis.info/tisv2/a/en/e90-335xi-lim/SEqbvP5
The key to getting the correct concept of the relationship of the cable length to the position of the sensor is that ALL cables run rearward from the sensor to its connector, and therefore the forward (Pre-cat) sensors have the LONGEST cables.
The other concern is the FUNCTION of the Pre-cat sensors (to trim enrichment or pulse duration of the injectors) is different from the Post-cat sensors (to monitor cat function and report any catalyst failure). So cable length aside, you may NOT get proper function if you put a Pre-cat sensor in a Post-cat position and connect it to the correct connector for that sensor.
Which raises another question: Are the O2 sensors connected to the correct connectors? In other words, is the REARMOST sensor, Bank 2, Sensor 2, which I understand is the one you replaced, connected to Connector X62202? Working on your bank can cause reversal or confusion of proper spatial orientation, so check against wiring colors shown in the Schematic, namely make sure it has a Black/Green wire instead of Black/Red (the other two wires are White/Gray, and Yellow, in BOTH connectors). As you also see from the diagram, the Pre-cat connectors have FIVE (5) Active Pins, whereas the Post-cat connectors have only 3.
If the vehicle is relatively new to you, perhaps you should assume that some previous owner or person who worked on it either/both (1) installed an incorrect part and/or (2) connected it to the wrong connector.
BTW, I have never worked on a 335xi, but to conduct the test I suggested, if the connectors are the same, you don't really have to move the sensors, just swap the sensor cable connections at the connectors (if you had the original/correct sensor in each Post-cat position). If the fault remains the same (P2272) then you do NOT have a faulty sensor 'cuz the DME is now receiving swapped sensor signals (Bank 2 Sensor 2 is now reporting to DME as being Bank 1 sensor 2).
Please let us know hot it goes,
George
