Consolidating all the PDFs
PM sent.Hello Shawn,
i´m new here and would like to code my F31 from 06/2013.
Can you also provide me the necessary tools?
Thanks a lot!
PM sent.Hi Shawn - looking to code my newly acquired '16 F15 50i - any chance you could send necessary software? Thanks for your help.
For the X5:Hi Shawn,
What car options for do i select for 2016 X5 35D. F10. Trying to figure out model. Thanks
Yes. You will have to Flash (program) it through.Hello,
Sorry if this is silly question, I've read the whole tread but still don't know.
I purchased a used lower door foot well module(FRM) for my F11 LCI and need to code it into the car to work properly. Can this be done with E-sys and how?
Thanks in advance!
PM sent.Hi Guys, looking for info & tools to code E71/2012 X6. Appreciate help here!
Thanks Shawn!!PM sent.
PM sent.Hi there
I'm trying to flash my FRM footwell module and EMF electromechanical parking brake.
I think I need the full version of psdZDATA as only have the lite version and any other help that I might need would be extremely appreciated
Thank you in advance!
You can read both CAFD and .NCD files offline using E-Sys CAF Viewer or FDL Editor accordingly....Next: As asked before, curious to learn about the equalizer settings, hence saved the CAFD files into my laptop and need to know if there is any software available to read the CAFD files in offline mode, to do research on the Harmon Kardon Equalizer settings.!
Hi Shawn,You can read both CAFD and .NCD files offline using E-Sys CAF Viewer or FDL Editor accordingly.
I have no idea. You just need to test them all and see what the results are. Anything you Code you can return to original Coding if undesirable. This is Trial an Error process from here.Hi Shawn,
After going through the CAFD files in offline mode, following modules look to be related:
1. CAFD_00000DED_003_015_007.ncd -> 3002 AUDIO_TUNER_TRAFFIC, 96
Logic7_Symbol
Audio_System_VAR
Audio System
Amplifier Variant
Multichannel
Audio Signal Routing
2. CAFD_00000DBD_001_007_000.ncd -> 3000 EQSetting
But not sure for the values for these settings, which enables the Logic7 EQ in iDrive :dunno:.
Any help or any source to get this info ?
Anyone know the settings how to make the LED headlights brighter (not the angel rings but the actual headlights) ?:eeps:I have no idea. You just need to test them all and see what the results are. Anything you Code you can return to original Coding if undesirable. This is Trial an Error process from here.
