Status
Not open for further replies.
201 - 220 of 371 Posts
Hi shawn
My PC harddrive died and when I went to the links you previously sent me they were not active can you please send me links for the latest pzdata and esys please
Hi shawn
PM sent.
Save
Save
I am old to coding but haven't done it since selling my 2012 335i. Just bought a 2016 x4 (F26) and I want to get back into coding. Can someone please send me all software. I have a new computer and accidentally deleted EVERYTHING for coding.
You would have had to delete it all anyway. PM sent.
Save
Hi,
Im new with codding and only want to change my F56 Configurations (like headsup with RPM). I follow all steps that I found on Bimmer and I get the connection with the car succesfully. The problem is 2 erros with my ESYS software. Anyone can help me? I generated a document in the link below (.docx).
Link:
https://www.dropbox.com/s/ad2tr097ge...ding.docx?dl=0
Many thanks to all!!!
Sato.
Save
Need F30 Change Language to Chinese Tutorial
Hi Shawn,
Could you send me steps or a tutorial for changing a US spec 2014 F30 to everything in Chinese Traditional Language? I have the multimedia package with the big screen and HUD.
I am exporting my car to Taiwan, so I don't care if navigation or any other U.S. feature is unusable or not.
Thanks.
Hi Shawn,
Thanks.
You need to add these Options to FA, and then Flash and Encode Head Unit:
8LT COUNTRY-SPECIFIC CONTRIBUTION 04825 ( Country controller Taiwan)
866 LANGUAGE VERSION SIPLIFIED CHINESE
8AS CHINESE TRADITIONAL / ON-BOARD DOCU
Then you can also load Taiwan Map.
Save
How to load Taiwanese Map?
Hi Shawn,
Thanks very much for the prompt reply.
When you said add these options to FA, does it mean adding 8LT, 866, and 8AS to SALAPA-Element?
And is there anything else I need to do to change iDrive and HUD to Chinese? Such as FDL coding...etc, or is adding these option to FA sufficient?
Best,
Hi Shawn,
Best,
Yes, as SALAPA-Elements, but just upating FA by itself doe snothing. You need to then Flash (Program) and Encode (VO Code) the Head Unit so it receives Chinese Firmware version.
Save
Is everything you said (flash, encode) can be learned from Beginners Guide Coding.pdf ?
In the end of the guide, it does calculate FP and write FP, this is just updating FP right? In the slide "What Next?", that is the flash and encode you are talking about right? :
Click on "Coding" button.
Read FA (VO).
Activate FA (VO).
Read SVT (***8230;
Right-Click on ECU (the ECU itself not the underlying CAFD).
Select CODE.
Repeat for all ECUs applicable to your project...
When the guide says right-click on ECU, does that mean right-click on the folder name (such as ACSM, AMP_TOPHB, CAS, CID...etc) under the list ECUs inside SVT box? And do I do this for all ECUs right, because there is about 30 of them...
After this, I don't need to do FDL coding correct? Thank you.
Coding is reconfiguring the functions within existing ECU firmware. Programming (Flashiing), is replacing ECU firmware with different firmware. It is far more complicated, requires PSdZData Full (not Lite), and car but be on a commercial grade charger good for 50 Amp minimum.
PM sent.
Save
Hello Shawn can you send me tutorials and the tools for programming(flashing) new software for e and f series?
I think in your case you need ISTA/P, but I cannot help with ISTA.
Save
Status
You have insufficient privileges to reply here.
