Status
Not open for further replies.
301 - 320 of 371 Posts
Save
Hello Shawn,
I have installed paszdata and already coded my F30. I coded the M performance logo and some other features.
Last week I took the car to the dealer because of a noise that sounded like a squeaky belt as the car is still under warranty. After 2 weeks, I got the car and the M logo was gone with the other features I coded.
Obviously they have recoded the car to default.. ( or that's what I think)
Anyhow, my question is have they recoded or flashed the DME? I am not sure whether my car was tunned by the previous owner.
Another question, can I use paszdata to code other cars? Like f10? Because I remember during the setup I had to choose f30 chassis.
Thx in advance
Hello Shawn,
Thx in advance
I have no way of knowing if DME was Flashed / Encoded without seeing the Final measure Plan report.
You can use E-Sys / PSdZData to code any F/G/I Series car.
Save
Coding for 2017 430i F33
Hi. I just purchased a 2017 430i F33 cabriolet and would like to make some coding changes. Specifically to Apple Carplay (which I already have in the car). Are there any codes specific to the F33?
Could you please send me:
The latest PSZdata and e-sys with installation guide.
Coding Library All PDFs on Instructions/ToDo's etc.
Coding made easy: Step by step instructions.
Download Links to Softwares?
PM sent.
Save
Save
Save
Save
Hi Shawn,
got my 2014 F20 successfully coded by myself with E-Sys 3.27.1 / PSdZData Lite 59.4
But got some issue :
A/C won't turn off anymore
No more splash screen animation display since I coded the M animation
Is this the lastest version ? If not, the lastest will be able to make it works ?
Hi Shawn,
Latest version won't make nay difference. Either you can code car or you can't, Since you can already code your car, different version won't matter one bit.
Save
Hi Shawn,
I'm cross-posting here because you seem to be the man to ask about everything regarding coding the F10 and after around 150 views in the general forum no one has responded. I'm new to coding for the F-chassis, the options seem endless. I've used E-SYS to code a couple of minor things (iDrive disclaimer, auto-fold mirrors, digital speedometer, etc.), but I'm looking to get 6NR and Internet/BMW Live working either through my phone or the car's telematics, as well as the Advanced RTTI (if possible). My I-level is F010-10-09-522, which, and bear with me, corresponds to ISTA/P version 2.39.3 or 2.39.4. My car was ordered with 609, 615, 639, 6AA, 6AB, 6FL, 6VC, 6UH. I don't have a ConnectedDrive menu, just BMW Assist. I assume this is because the firmware of one of the modules either needs updating or the entire I-level needs updating. Perhaps this is why sport displays and a couple of other options I coded aren't working.
I don't want to go past 2.42, since it's my understanding that BMW requires an FSC for 6NR activation with versions after that. If I'm reading correctly though, if you code out 639 you also lose Bluetooth.
Another potential issue is that I did a SIRIUS retrofit through Bimmertech, so if I did a complete I-level update, which I have no idea how to do and probably wouldn't attempt, am I going to have to pay for another FSC?
BTW, we have the same build month/year. Sibling cars!
Save
Hi Shawn,
I am not entirely sure what your question is beyond iLevel Update, and to answer that, Yes, you need 2.41 / 2.42 else anything higher and you will need an expensive 9C FSC Code. With newer 2.41 / 2.42 CIC firmware, and proper coding for 6NR, you will get Connected Drive Menu / BMW Apps.
And yes, you can udpate I-Step and it will have no impact on any Existing FSC Codes including your 6F Sat Radio FSC Code.
Internet / BMW Live is possible via Bluetooth Tethering by disabling of all Telematics and Coding using VIN with Authorization, which I detail here:
http://www.bimmerfest.com/forums/showpost.php?p=7091176&postcount=70
I warn you now though, Internet / BMW Live on car / iDrive is absolutely worthless, and not worth the difficult effort to make it work.
Save
Hey, Shawn, even being a mercedes owner im happy to see you there helping out other people with coding. In near future im about to buy F30 as replacement to w204 restyle and im reading now some coding guides from Russian and European side of internet. You have done a great job there, I enjoy exploring this. Mercedes is much harder to code, seems like BMW doesnt lock their ECU's
Yes, BMW is much easier than MB or Audi.
Save
Status
You have insufficient privileges to reply here.
