Consolidating all the PDFs
Okay, I get it. Basically, ESYS has a database that maps the FA's content to all ECU's FDL's datas. Is it correct to see "VO coding" as an "automated FDL coding" essentially (based on the VO)?Be it factory FA or a modified FA, based on the Option Codes (SALAPA-Element, HO-Wort, and E-Wort) specified in that FA, when you select "CODE", E-Sys will Code every Function Data Line (FDL) of that ECU to predetermined settings necessary to support all the Option Codes. The predetermined settings are based on a variety of FA parameters such as the vehicle Type Code (e.g. TypschlĂĽssel=FR73, which equates to 535i Limousine N55B30M0 225kW Rear-wheel driveon the left USA ), and the vehicle Build Date (e.g. Zeitkriterium=1211), and are defined in the PSdZData KIS Database files.
MY 2013 is an E70.What series is a X5 2013? Which should I use for coding?
You need to update your PSdZData.I have a BMW f10 535i 2011. Production date 2/2011.
I am using e-sys 3.25.3 and psdzdata 50.3
I have coded most of the features from the cheat sheet that I wanted without issue.
However I cannot seem to read CAS-> CAFD_0000000F_005_025_037
I keep getting error that its not found.
Does someone have any ideas?
PM sent.I'm new to this!
I have a 2003 bmw 330xi AWD sedan and 6-71 blower! Where can i get software that I can download to my ECU!
USB Video only works with newer NBT Head Unit.Hay
Is there an option to code F10/11, year 2011, to be able to play videos (divx, etc…via USB port (and various media)?
I try to code it ... but cant find the option in the HU_CIC:
API_USB_VIDEO => both
ENT_CODEC_XVID => aktiv
ENT_CODEC_VCD => aktiv
So is it possible or not?
Also I tired to make sport display (torque an power). They showed up, but it does not show anything .. no pointers moving
HU_NBT => 3000 => EFF_DYN_SPORT_CID => aktiv
HU_NBT => 3000 => EFF_DYN_SPORT_UNIT => aktiv
Any help?
Thnx
Cheers.
Dear Shawn Sheridan!You need to look at F30 Cheat Sheet:
https://docs.google.com/spreadsheet/ccc?key=0Ahod4s9syxhNdGZyaGFWd1pnNWE0UEJNR0xIa3ZmbUE#gid=0
Read I-Step Current from VCM:Dear Shawn Sheridan!
Can you please also send me the link for E-sys and all necessary other data for coding?
Is there a list for checking which I-Level I got?
The problem I think is that I do not have E-Sys for checking I suppose...
I got coded some features from an expert and may ask him....
Thanks in advance!
It's fixed now.Thank you!
Problem: Mega.co file says temporary error, so I can't download the file!
:dunno:
