Consolidating all the PDFs
Hello! sorry for bad timing, but could you please send me the instruction on how to update modules with e-sys, i had searched a while but couldn't t find it(i'm no SherlockNo. There is no such Guide.
PM sent.Hello! sorry for bad timing, but could you please send me the instruction on how to update modules with e-sys, i had searched a while but couldn't t find it(i'm no Sherlock)
thank you, and keep the good work! have a nice evening.
If dealer updated your car to 55.x, and you use 54.1 PSdZData, how is Detect CAF for SWE going to find compatible CAFD files for these ECU's with newer firmware files? It can't. You need to update to 55.x PSdZData.Goodday for everybody!
Last week dealer has updated my car (F30 320xd, sept2014) and so my current i-step is F20-15-03-502. I've tried to do FDL coding using E-SYS 3.26.1 and psdz-data 2.54.1.
At first I get this error:
FEM_BODY [40] [PS96774]
readCPS o.k.
CAFD_00000794_012_037_005 Fehler:
File for "cafd_00000794-012_037_005" not found! [C012]
Usually it can be solved by Detecting CAFD for SWE, but when I try to do it, I have another error:
FEM Failed to get CAFs for SWE "swfl_0000155e-012_200_030". [C111]
KIS error: Die technische Einheit 0000155E konnte in der KIS-Wissensbasis nicht gefunden werden. [1283]
I have the same errors on every module except KOMBI.
What does it mean?
Can I solve it using VO coding?
Need help please!
You wrote:Thank you very much for PM!
How should I understand that dealer updated my car directly to 55.x?
F20-15-03-502 is either 55.1 or 55.2.Goodday for everybody!
Last week dealer has updated my car (F30 320xd, sept2014) and so my current i-step is F20-15-03-502. ...
You no longer need 2.54, so you can delete the entire thing.Ok. Today I'll try to do it.
I found that the folder with psdz-data 2.54 takes 34Gb of memory. New psdz-data takes only 1.6Gb. What files can I delete from old data?
Also I want to install Rheingold to delete errors. Maybe you know where I can get it?
I need previous version psdzdata to code my friends. You know what I can delete to make it lighter?You no longer need 2.54, so you can delete the entire thing.
Sorry, I cannot help you with ISTA/D (Rheingold).
Why is that? PSdZData is backwards compatible. You can use latest PSdZData to code any Fxx car.I need previous version psdzdata to code my friends. You know what I can delete to make it lighter?
Today I tried with new data 55.1 lite and had new error while activating FA or Reed coding data on ECU:If dealer updated your car to 55.x, and you use 54.1 PSdZData, how is Detect CAF for SWE going to find compatible CAFD files for these ECU's with newer firmware files? It can't. You need to update to 55.x PSdZData.
PM sent.
Did you open E-Sys directly or did you use E-Sys Launcher? You must use E-Sys Launcher, else you will have no active .EST Token solution.Today I tried with new data 55.1 lite and had new error while activating FA or Reed coding data on ECU:
No FP could be generated from FA "". [c002]
Developer signed CAF (signed with personal EST file) cannot be processed - no EST or EST-CM found. [1461].
Finita la comedia?:tsk:
You need to update your PSdZData....
However, I'm getting the following errors:
DME [12] [G211563]
readCPS o.k.
CAFD_000001A7_000_014_020 Fehler:
File for "cafd_000001a7-000_014_020" not found! [C012]
HU_NBT [63] [G211563]
readCPS o.k.
CAFD_00000DED_003_014_012 Fehler:
File for "cafd_00000ded-003_014_012" not found! [C012]
KOMBI [60] [G211563]
readCPS o.k.
CAFD_00000069_010_001_110 Fehler:
File for "cafd_00000069-010_001_110" not found! [C012]
RDC [20] [G211563]
readCPS o.k.
CAFD_00001F3F_004_003_001 Fehler:
File for "cafd_00001f3f-004_003_001" not found! [C012]
Thanks Shawn,You need to update your PSdZData.
PM sent.
Hi Shawn,You need to update your PSdZData.
PM sent.
Hi Shawn, I coded my 2011 F10 two years ago and had turned on all the cool features with the help of you and this site. At the last oil change at the dealer, I guess they updated the software and I lost my coding. Today, I used the same laptop, cable and software but ran into errors on Clicking SVT "Read VCM". Did something change since then as far as the E-Sys software? Do i need to download newer E-Sys?
Thanks for all the help.
Shajan
You need to update.This is the error.
