2,181 - 2,200 of 6,169 Posts
Hello @shawnsheridan - Thank you for all your contributions to this great hobby and this forum
I have successfully coded many cars in the past so i am fluent in the subject
I just bought a certified pre-owned 2016 G12 however during the car prep the BMW dealer flashed it with an i-level dated July of 2020. It is not listed in the I level overview in the latest link.
I am using esys 3.27.1 or 3.30.1, launcher 2.8.2 pro with psdzdata lite 4.21.32
Because of the most recent I-level programmed to the car i cannot seem to edit the FDL's and the cheat codes do not work
Any chance you have a very recent psdzdata that would encompass an i-level dated last month for a 2016 g12 ? (I am sorry i dont have the actual i-level as i am typing)
even my version of ista does not have this i-level - i guess its time to upgrade this too
I really want to silence the seat belt reminder, it is quite annoying !
Thank you again
PM sent. For Gxx car, you likely need E-Sys Launcher PRO 3.7 or E-SysX for the latest ECU CAFD Mapping as E-Sys Launcher PRO 2.8 is not current enough, and these can only be obtained from the developers direct.
Back in action! I've updated my 2015 328i Xdrive to 4.23 and it's good... but I kinda miss the fake engine noise and the ability to have more than 3 turn signal flashes. Even the exhaust pops and bangs are more subdued in the latest versions.
I've read elsewhere that you can possibly revert back to older firmware versions, as long as you didn't go beyond your build date (3/15 for me). If so (flashed my car a few times successfully so far, had to use different E-SYS versions for NBT.. good times). Do you happen to have PSDZADATA Full 3.51? I think that is the one for my build date.
The fake engine noise was nice to clear out the AC low pressure hose whine.
Thanks and great to see you back, Shawn! (Read a LOT of what you've contributed)
Could you PM me the link also please?
All I wanted is to configure the "SET" button on steering wheel as LIM function (speed limiter).
I use this function dairy on my old car, disappointed to find my new i3 didnt have this function...
PM sent.
hi guys,Long time lucker here, hope someone could help me.
I followed all the steps at the start to install e-sys and launcher etc but I have ran into a problem when I launch e-sys. When i try click settings e-sys crashes and nothing happens.
Hi i try to code my headlights moduls after changing them because af crash.
When i try to read coding data following information comes out.
CAFD_000024C3_010_080_001 Fehler:
Lesen des CodierprĂĽfstempels von ECU "ECUId:FLE_0x44" fehlgeschlagen. [C070]
negative response error:
code: TIMEOUT P2/T2 occurred
description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: FLE_44_ETHERNET
severity: ERROR
[2130765072]
did you have any advice for me?
Thanks for the suggestion, but unfortunately still crashing.
What is your Windows Build version. Right click on windows start button, RUN, type "Winver" and Enter.
