2,581 - 2,600 of 6,169 Posts
Hi Guys!
I've got the following problem:
I have installed E-Sys 3.28.1 which worked fine in summer when I used it the last time. Launcher is Launcher Pro 3.0.4.90. But since yesterday there comes the message in Launcher Pro "This application requires an activation code. If you don't have one you may login to fxxtokenmaster.com to request one. Well I tried but there I can't find one on the site. It says "You do not have any active key. Contact TokenMaster to request a key. "
Could anyone tell me what to do? All I need is to be able to code again.
I also tried to download the 3.27.1 because I thought this works without launcher but it doesn't (missing EST File).
I already tried to find the solution by reading here and fxxtokenmaster blog but I think I haven't understood what the current steps are.
Thank you so much!
Hi Guys!
Thank you so much!
No idea why your Launcher PRO 3.x Activation is jacked up, but only TM can resolve. Short of that, you would be stuck using older Launcher PRO 2.8.2..
Unfortunately he doesn't answer to emails. So it seems to be an issue with this version of the launcher I think
A friend with the same configuration has the same problem...So it seems to be an issue with this version of the launcher, I think.
Where do I get Launcher Pro 2.8.2? Is this a free version? How does ist currently work with getting Esys? Is it still with a donation to TM? As I can see you've got links for the current version.
From TokenMaster's Blog:
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST
Posted by TokenMaster at 6:16 PM​
Links are there:
E-Sys Launcher PRO 2.8.2???
Oh... of course... Shame on me! I've already found this, yes. Therefore I would have to uninstall my 3.0.4.90 right? Are there any disadvantages with the older launcher? Will it work with esys 3.28.1?
Thank you!
Older version will not have as current CAFD Mapping as newer version, so maybe some ECU CAFD that worked, will be trimmed in older version.
Hello, I bought an esysx, can I have a link to the latest esys?
Thanks for advance!
I use E-Sys 3.27.1 for coding and 3.30 for CAFD injection and flashing. No need nor benefit for any newer E-Sys.
  • Like
Reactions: Marracoonda
