3,061 - 3,080 of 6,167 Posts
Hi @shawnsheridan can you send me the link of the latest PSdZdata for my F10. I am looking to activate speed limit info so do I need the full version or lite?
My car already has a KAFAS 2 camera so its purely a software retrofit...
You need SLI FSC Code and Coding, so only PSdZData Lite is needed. PM sent.
Hi
Does anyone have a link for the latest ISTA+ ?
I have to do something on a late M2 CS with the last software update
Many thanks in advance
Wrong Thread. ISTA is Diagnostic and Programming software, not Coding. Sorry, I cannot help with ISTA.
Hi,
can someone help, I had many things coded in FEM_BODY, and now after the service action I get the message: CAFD_00000794_018_070_005 Fehler:
File for "cafd_00000794-018_070_005" not found! [C012]. I have E-Sys 3.27.1 Launcher Plus 2.8 and PSdZData Lite v 62.3.
All I know is that I have to use the button: "Detect CAF for SWE". But I don't know if I need to download a newer version of E-Sys and Psdzdata? And is LITE enough or do I need Full?
Hi,
You do NOT need to inject CAFD ("Detect CAF for SWE"),
Update your PSdZData (Delete & Replace). PM sent.
  • Like
Reactions: deusexe
Hi, I'm brand new to coding and I've done a little research and gathered my tools (E-Sys, psdzdata) and have a quick question. I am trying to code an LCI F10 (2016 535i)
Before I say anything else this is my software setup:
  • E-Sys Launcher PRO V2.8.2.162 BFU_XODE Edition
  • BFU_XODE.EST token file
  • E-Sys 3.27.1
    • UNCHECKED "Update VCM after TAL execution"
    • UNCHECKED "Update MSM after TAL execution"
  • psdzdata lite v4.30.12
I have setup the launcher, token, psdzdata, and pretty much everything and it all works well, no problem there. I have a question about the connections I can make to the car in E-Sys.
I know I have to select the F010 chassis, however there are more than one to choose from. (I know NOT to choose the "_DIRECT" options)
1038033
Which one do I choose for my car? I looked and people said "choose the one near the bottom" but I don't really know why to do that, or if it is the correct thing to do. If someone can tell me what the "TargetSelector" text means and how to read each option in the list that'd be helpful. Also, I just want to make sure there is no psdzdata version mismatch between my car, E-Sys, and what I need.
Choose bottom (newer) one.
Thanks, are there. any cheat sheets for 2016 LCI F10? The ones I have are all 2011 pre-LCI model.
Very little is different in terms of coding.
  • Like
Reactions: Quoc Auto and 3Side
