3,621 - 3,640 of 6,164 Posts
Does it possible to code slz module after chaning it with e sys and psdzdata lite ? Or i need full psdzdata if yes maybe can i get a link to download it ?
All Coding can be done with Lite. Full needed only for Flashing.
I think that you have a lot experience on it. So maybe cauld you help me a little bit? I have F07 2010 year. And i changed szl module. But i need to code it. Cause my active steering wheel doesnt work. I was looking a lot of guides , but didnt find info about it. Just i know that my szl in e-sys lights black , non of codes in slz module lights green all of them is black
If you replaced SZL, then you need to inject CAFD into SZL and VO Code it.
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired SZL => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on SZL (the ECU itself not the underlying CAFD) => Select CODE.
And here im getting problem that i can’t select the CAFD the button is disabled 🤷🏼‍♂️
You cant use E-Sys 3.27.1. Need 3.30.1 or higher.
I'm trying to find the download link for ISTA+ (Rheingold) - have a check engine light on but no other errors. Car drives ok. 2014 535d xdrive
Sorry, I cannot help with ISTA. New version of ISTA requires a PC HWID specific license file to run.
