3,761 - 3,780 of 6,169 Posts
Discussion starter · #3,769 ·
Is this something that a novice can do? Any instructions on that? Or anyone here who can assist with that?
Yes.
I have been trying to inject cafd to my cluster which is a Bkombi and still no luck any help please would be appreciated
2011 base kombi
Error fault was initially smgb mismatch but now the whole cluster is dead and it only has the high beam symbol flashing
2011 base kombi
is orginal cluster or you made retrofit?
Try to flash kombi, cafd will be added
Hi Adalbert & thanks for the quick response.
Cluster is original. I tried to flash it and the flashing procedure goes successful (only blflash).
Problem is i cannot do swDeploy, ibaDeploy or cdDeploy.
I believe the the issue is the i-level or the psdz files im using. Unable to confirm exact cause. Shipment i-level f20 11-11-504.
Thanks in advance
Thanks in advance
you can make reflash module or new newer psdzdata, sent pm
