441 - 460 of 6,169 Posts
Can I code an April 2018 F30 320d ?
Hi All.
I am a completely new member, and this is my first post.
Currently(but only for 3 more days) I drive an 320d E90 2008, which I have coded a lot of stuff on. That was easy and worked fine.
In 3 days I will be taking delivery of my brand new from factory, April build 320d F30, and I have been looking into how to code that.
A lot of threads have been read, but I am a bit confused regarding E-sys and Launcher (Pro), and also, is there PSD data available for such a new car ?
To make sure that I use the correct E-sys and Launcher, what is the combination to use ? Tokenmaster has not answered my email regarding getting hands on launcher pro, so I dont know if there actually is a combination of Laucher and E-sys that I can use, that also has the correct mappings and so on ?
Could anyone please enlighten me regarding coding such a new car, and if someone has done it with which combination of tools and data ?
Thank you for a great forum :)
Discussion starter · #444 ·
For an F30, Launcher Premium will work fine.
PSdzdata is not split by chassis. You download entire set.
As described in OP, use E-sys 3.27.1 and either Premium 2.8 or Pro 3.1.
Discussion starter · #445 ·
So I will have no problems regarding the mapping issue ? Read somewhere that BMW has removed some help from PSD Data, and these are mapped via the Launcher ? Is this working 100% in the Premium version with E-sys 3.27.1 ?
And.. is the latest PSD data available for a model build April 2018 ? As I understand, there has been changes made to the cars from March 2018 an on.
For G-series, you want Pro Launcher. For an F-series, Premium is fine.
I keep links updated with latest Psdzdata.
I'm using E-Sys 3.27.1 with the latest PZData and it works great with my 2015 F10. However I also have a 2017 F56 Mini Cooper and I cannot get it to connect - is it a version mismatch issue? Do I need a newer version of E-Sys?
Really new I-Step
Hi Almaretto
I have just updated my PZData from your mega link (thanks), however my car has a newer version than that in the file. I cannot FDL BCD_BODY, but now all the others work.
My car has F056-18-03-532 and I believe the latest in the file is F056-18-03-524
I am just wondering what sort of time window there for the mega file to be updated?
THanks
Matt
Hi Almaretto
THanks
Matt
Are you getting a Missing CAFD error, and if so, which CAFD?
Thanks for that
I can now load the CAFD but get an error when FDL coding the changes
I have attached screenshots of the error.
....does not support FA2FP version 001.xxx etc
Close, but no cigar.
Any help would be appreciated
PM sent.
Bonza (as our Australian cousins would say).
All works as it should.
Can't find ASCM- 3000 SEATBELTREMINDER_FAHRER any more, but that is probably a good thing!
Also can't get BDC_BODY BLINKZYKLEN_ANZAHL_TIPP to change either, but will look for PIA change etc.
Appreciate all your help.
Discussion starter · #456 ·
ACSM parameters are still present. You will not find BLINKZYKLEN_ANZAHL_TIPP.
