6,081 - 6,100 of 6,164 Posts
Hi All (but probably Shawn as he seems to be the one that replies to all the other comments).
Could I also get the links to the esys/psdzdata/other software required for the g80/g82/g87 platforms.
Thanks a lot!
Guy
hiya, can i please get the links for all the software needed for f30?
thanks in advance!
PM's sent.
  • Like
Reactions: someguyoz
Hi folks:
I'm still trying to learn coding. I coded VLD through Bimmercode on my Laser light and it's been fantastic! But I want to change KAFAS settings to optimize its performance. Can I get links for the software needed for G20 and G01?
Hi folks:
PM sent.
Hi @shawnsheridan
Could you shoot me the links to the latest coding software for a 2017 F54?
I’m about to do a reversing cam retrofit and just realized my tools are kinda outdated.
Appreciate it, thanks! 🙏
PM sent.
Hello, First post here. I have been reading (Trolling) just about everything I can for about a month and still can't get my problem solved. I had a left headlight swamped with water and have replaced the entire headlight housing, module, ballast, and replaced the connector to the car My problem is I went down the road of not knowing what I was doing, and it seems I may have programed the FRM to do something strange. My right front headlight works fine but my left headlight will not light low or high beam. The left turn in (corner) light will not illuminate either. And to top it off the break lights are constantly on and I replaced the break light switch but that did nothing. My assumption is that I messed those up when I messed the FRM up.
Like I said , I have ISTA+ running and also have a working e-sys and launcher working but need to know what PSZD FULL file for my car as I can't seem to locate that either.
Any help would be appreciated as I have been at this for over a month and I am getting no where on my own.
My car is listed below:
2012 BMW 528i XDrive manufactured 7/11 (I believe)
F10 Series
I have adaptive headlights with Xenon low / high beam
Halogen corner lights
LED turn signals and marker light
P.S. I did order a used footwell module coming this Monday or Tuesday with the same sw, hw, production date, and part number. Just in case I can program my vin on it and get back my car.
Thank you for reading. Please help if you can as I don't know what to do next.
Thank You.
F10 Series
Thank You.
PSdZData Full needed only for Programming (flashing).
If you have any sort of coding issue, just VO Code FRM and any separate light modules to reset them.
Hi guys!
Can you please share links for latest ISTA+ and PSdZData, and E-Sys too if possible. Having issues with bluetooth connections in my 2015 f15 and trying to update software.
PM sent.
Thank you for the response.
Can I ask how? I assume you are telling me that lite will do what I need but my model is not in the light version I have. As well no sure what VO code FRM means.
Can I ask what version I need if you know?
Thanks again for reaching out.
Use whatever psdzdata you have, and:
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Right-Click on FRM (the ECU itself not the underlying CAFD) => Select CODE.
I tried what you said and got the following posted completion notice as well as a file saying complete also attached. Thank you for that.
My next question is how do I code the adaptive lights lights to work again? I have an XTool that resets the headlamps and trains the turn in's. Should I use that or use ISTA+ or something totally different in E-Sys?
Thanks again for your help. I really do appreciate it.
What is VIN (last 7)?
Old F10 with Adaptive Xenon lights has only FRM, no individual Light ECU. If FRM is VO Coded, only think left is Teach-In with ISTA.
did the teach in with ISTA+ with no luck
Still have
Adaptive Headlight malfunction
left Low Beam Malfunction
Left Corner light Malfunction
Left low beam / high beam headlight does not work. Break lights still on all the time. Left turn signal (LED) does work.
I am lost. At this point I am not even sure it's a code issue but as in OP I replaced the left headlight housing complete and left headlight module. Only thing left is that the module is wrong for vehicle. but I tried 4 different ones.
Any ides where to go from here? I would ask if anyone would like to connect to my machine and I would gladly pay a fee at this point. As long as it's not BMW Pricing LOL.
Still have
Sorry, I have no idea.
