Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#3,190 ·
No way that I know of. On some new cars, Remote Start can be ordered from ConnectedDrive Store.
#3,195 ·
Help, stuck while trying to retrofit electric tailgate in my F11 MY2011 535i. Managed to add FA316 to relevant ECUs except for the added used HKFM module which need CAFD. Cannot add as it's greyed out using esys 3.27.1 / launcher 2.8 / psdz lite - according to Shawn I see the psdz data is too new. Tried installing 3.30.0 but cannot get launcher pro for it... Will I be able to add CAFD using 3.27.1 and older psdz data?
#3,196 ·
You use Launcher ONLY for FDL Coding. For CAFD Injection and VO Coding, you use E-Sys 3.30 and NO Launcher.
This post has been deleted
#3,215 ·
Hi Shawn,
Could you help me with esys + launcher +psdata to BMW F15 2017? (I need links to download and install these programs)
This is actually my first BMW ever in my life and my first time coding, I need help with esys coding Video in Motion.
I had already done some bimmercode coding on the car, just some minor stuff, ambient lighting, driving mode start with sport etc......just the easy mode stuff.
Please guide me through !
PM's sent.
#3,214 ·
Hi Shawn,
#3,218 ·
Hey Shawn can I please have the link to the latest psdata full? Feeling a bit defeated here. There seems to be an abundance of dead links and misinformation out there :-\ Trying to code my rear rotors to 345mm on my F30.
PM sent.
  • Like
Reactions: delorean175
#3,219 ·
From TokenMaster's Blog:
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST
Posted by TokenMaster at 6:16 PM​
Links are there:
E-Sys Launcher PRO 2.8.2???
  • Like
Reactions: bestwick
