1,361 - 1,380 of 6,169 Posts
Try this:
Launch E-Sys
Click "External Applications" in the left menu.
Click "External Application"
Double-click "Transmitter"
Select "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS - DM_Lock,clear ZFS - DM_Clear,ZFS - DM_Unlock)"
Set "target diag addr" = DF
Press "Connect"
Press "Send"
no good it flashed but the codes still stayed
Then something is not right. What ECU's are musing CAD or have corrupt CAFD cafd_ffffffff-255_255_255?
sorry not sure I follow should I try again on a factory reset?
No. Check ECU's in ECU list, and look for missing CAFD of corrupted CAFD as I worte.
use f025_19_03_550_v_004_003_000
how can I tell if a cafd is bad?
Connect to car and Read ECU List, If you have coded car, you know how.
Press Read (ECU). Look at list of ECU in left Pane.
Which ECU have no CAFD or a Corrupt CAFD (e.g. cafd_ffffffff-255_255_255)?
Pay attention to DME ECU...
I did read it and all shows fine ECUs (26)
You are not doing what I wrote.
Again, of your 26 ECU, which ones are Missing CAFD or have corrupted CAFD (cafd_ffffffff-255_255_255)?
Your DME is surely missing its CAFD.
You need to Inject CAFD and VO Code DME now:
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on DME ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
1) You can NOT be running motor when you do this.
2) Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. PM sent.
Thanks Shawn I will give it a shot.
Shawn you are the man sorry for miss understand your point it all comes clear when you understand :) Worked perfect. I did go back into Launcher PREMIUM and ran the clear codes because it still had a traction code error but this time it cleared them.
Lesson learned code with engine on but resting the ECU engine off...
Thanks again for taking the time.
John
John
:thumbup:
VO Code or FDL Code with Motor running, except when coding DME module. Since it is the motor module, it can't be running while being coded.
Hi Shawn,
Can I have the link towards last E-sys psdzdata full? Just bricked my 6wa kombi with carly and I would like to get it back to his senses :)
Thanks.
PM sent.
Been coding FDL and will attempt to code VO I need to add 322 I understand it will override my FDL no problem my questions is, I understand the first part of adding the 322 but when going back to Expert mode I code the HU_NBT2 and not the CAFD correct? Second part is which other parts of the ECU need to be CODE when adding 322?
John
John
Yes. Right-Click on HU_NBT (the ECU itself and not the Underlying CAFD) and select CODE (not Code FDL).
Thanks Shawn is that the only one I need to code when aiding 322.
Why are you VO Coding car for Comfort Access? This is a retrofit? You added all the hardware?
