1,381 - 1,400 of 6,162 Posts
I have all the features coded but I'm missing the handle so I was going to pick one up and see if I can make it work.
Did you add all the CA hardware?
Question I coded the wife's car to have the mirrors fold up on lock/unlock all works fine from the fob however, pulling the handle or locking it with the touch of the handle does not always fold the mirrors even though it locks the car each time. Any idea why it would be hit or miss?
No idea. It should either work or not work. Are you touching the handle ridges long enough for the folding to engage?
Nom idea. It should either work or not work. Are you touching the handle ridges long enough for the folding to engage?
Thanks Shawn I tried it and it you touch the handle it will unlock however it will not unfold. If you grab the handle and open it it works fine. Same with locking you have to hold it a sec longer and it folds.
Check your coding as follows, in particular the blue ones:
KOMFORTOEFFNUNG_FB = aktiv
KOMFORTSCHLIESSUNG_FB = aktiv
KOMFORTSCHLIESSUNG_PA = aktiv
KOMFORTOEFFNUNG = aktiv
KOMFORTSCHLIESSUNG = aktiv
KOMFORT_SCHLIESSEN = werte=00
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv
I will check again tonight thanks
hi guys ! ...
the launcher will be expired till 21st april 2020 ...
It's the true ?
what can i do for extend the expire date ?
I needn't the last version .. i use esys only for my car for little coding ...
thanks
Roby
You can use E-Sys Launcher PRO 2.8.2 for free until April 2020 when it expires. You cannot extend date.
After that, you need E-Sys Pro 3.x or use E-Sys PREMIUM 2.8.2 with Rearm Script.
Hi guys.i have bought door handels with led light exterior.my original handels without led light.i wanna retrofit them.anyone have idie how to wire them or have wire diagram? My car is f10 2011
Thanx
You stand a much better chance of getting help if you Open a new Thread, rather than posting about Handle Wiring in "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" Thread.
