1,501 - 1,520 of 6,169 Posts
My car got updated from the dealer and the 4.21.32.7 psdzdata seems to be out of date. Is anyone aware of current psdzdata that will allow me to code my BMW i3?
PM sent.
Hello,
NcdCafdTool_V0.5.2 does not work with the last NCD files from PsdZdata 4.22.14 and Istep S18A-20-03-524 ? I have and error when I opened the NCD file. I tried in two notebooks with Win7/64 and W10 and is the same error.
Thanks,
Miguel
Hello,
Thanks,
Miguel
Generally speaking it does not support newer CAFD files. NCD CAFD Tool is quite old and obsolete.
No, TokenMaster has not released a newer version yet.
You can easily compare .NCD files by reading and saving them in E-Sys as FWL files and then using Beyond Compare or WinMerge to see the differences.
That's not entirely true. First of all, there is a newer version but it does not seem publicly available and second one guy has found a way to make newer mappings work with it (and Launcher Pro 2.8.2) but as so often in this area he will not share his knowledge.
https://www.carcodingnord.de/blog
I am not sure what part is untrue. :dunno:
NCD CAFD Tool v.0.5.2 is outdated, and there is no newer release. An unreleased updated Beta version in development by Token Master and an unreleased hacked updated Database for existing version does not chnage this fact.
Hello, bro! I need a software for coding my M5 F90.
https://github.com/siegester03/bmw-f I read here what I need.
But when I launch E-Sys launcher premium (v. 2.8.2.155) she asks to enter the key.
Can you give me all software what I need?
Thank you! :)
Thank you! :)
E-Sys Launcher PREMIUM 2.8.2 .EST Token expired 12/30/2018, and for now there is no update.
Instead of E-Sys Launcher PREMIUM, you can use E-Sys Launcher PRO 2.8.2 for free, at least until April 2020 when it expires:
http://tokenmaster.blogspot.com/2019/05/e-sys-launcher-pro-282.html
After 4/20, you will need to get licensed Launcher PRO 3.x or E-SysX.
Hi. I have F30, so can I just leave only F20 folder and remove other ones? Full pzdzdata takes a lot of space on my drive (
What will that save you? Not much at all. The firmware files are not split up by chassis.
Put psdzdata folder on an external HDD and use MLINK command to link it back to E-Sys.
Thank you! And what about E-SYS + PSDZData? Which versions I need? I just want to add new colors in the cabin, video in motion, etc.
PM sent.
Shawn -
I have ISTA+ up and running for my E90, F25, and F55. I'd like to do some coding for the F25 and F55 (both 2016 models). Which version of E-Sys and PSDZData do I need to do that?
Thanks in advance!
PM sent.
Hello guys,I am from Turkey. I'm new to the forum. my car is 2016 f10. my car has a ghost screen and nbt. Where can I find the current code list for my vehicle.
Cheat Sheets fell out of favor for built-in Launcher Cheat Codes years ago.
I want sport + ,reversing door led lighting code please.
F10 Door Handle Lighting in Reverse not possible.
For Sport+, in FA, change 205 or 2TE to 2TB and VO Code KOMBI, EGS and ICM.
