1,541 - 1,560 of 6,169 Posts
Hi Shawn,
In the same boat as other folks with the 2.8.2 E-Sys Launcher Pro boat. Sounds like the solution is E-SysX? Or are there other alternatives?
I'm using the PSdZData 4.21.32 as downloaded from the first post--is that still the latest link or is there a more recent one that you're sending to people?
Hi Shawn,
PM sent.
Hey everyone!
what ist the Key for the PSdZ data? Or are there newer PSdZ data?
Thanks in advance!
There is no "Key". What are you referring to?
Latest Full version availble is v.4.22.31.
After Downloading the PSdZ Lite data from the Link in the Post it wants a password to unzip the file.
greetings
If you mean Link in Post #1 for "PSdZData_Lite_v4.21.32.7z", I just downloaded and Extracted. No password needed.
Does anybody know where to get Ista-p? I've got a little coding issue and I think Ista could help.
ISTA/P is for E-Series Programming only. That can help you with F-Series car? :dunno:
Hi Shawn,
Hi Shawn, can you send me your suggestions for a solution to the now expired software as well. Thank you!
Mhm, okay, I try to explain my problem:
I tried to code my father's i3s with E-Sys and the newest PsdzData 3 days ago. As always I changed the parameters (1: VSG Last_user_mode, 2: IHKA AC_On_with_Auto, 3: BDC_Body Fesinimode) then I clicked "Save" and latet on Code FDL. It seemd to work like usual and at the end there was a small Errormessage in the Window that pops up after every coding but I can't remember it. The result was that there were no changes saved.
I retried, with the same result and then, I reconnected the car and maybe I made the mistake and chose an older Softwareversion (19_07_562) in the first Window hat appears after clicking Connect.
I did the coding again and after that the VSG and IHKA Cafd were gone (disappeared) and the BDC_Body was set to fffff 255.255....
Now I have some error codes in the error memory and I can't access IHKA, VSG, BDC_Body anymore.... The AC doesn't wok anymore.
Any Ideas what to do? And what went so wrong?
BDC_BODY has corrupt CAFD. Inject new CAFD and Encode ECU.
Okay, that sounds easy :) But I have no idea how :dunno: - Sorry
And you do not look hard to find out either as I have written how dozens of times in multiple threads.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
* NOTE: Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher.
And this Thread is only for software request, not diagnosis / coding.
I'm sorry I haven't read the whole thread, that's true. Thank you that you wrote the answer again for me!! I'll try that tomorrow.
Any ideas for the other two problems?
Fix BDC first and worry about the rest later. They may go away after BDC is working again.
