1,641 - 1,660 of 6,167 Posts
Thanks Shawn for detailed pm. Do you think there is a way around the .EST token expiration on v2.8, i.e. disconnecting laptop from internet and changing system time. then re-installing launcher or something similar? is E-SYsX free? if not, are there any other free solutions to code F10?
I have PM'd you the only 3 Options I know.. Launcher has Built In Date Manipulation Detection and E-SysX is not Free, rather it's quite expensive. Best Option for replacing the expired Launcher PRO 2.8 BFU is Launcher PRO 2.8 with new .EST Token and Activation.
Hello Shawn, can you also PM methe known ways to get passed the expired EST file?
thx
R
All I want to do is change the function of automatic headlight setting (to run angel eyes day time, and normal full headlights during night time). Is there any other tool besides ESYS that can be used to program this in F10? Prefferably free.
You can VO Code that and VO Coding does not require Launcher, only FDL Coding does.
Thanks Shawn, i am sitting in the car as im writing this, followed a VO guide you provided in this forum, I couldnt find a VO cheatsheet. would u know how I can change the previously mentioned headlight setting using VO? In the past, I done it using FDL...
Try Option Code 8TL or 8TN as you prefer:
8TL_DAYTIME_LIGHTS_FRONT_AND_REAR_ACTIVE
8TN_DAYTIME_LIGHTS_ABOUT_LIGHTMENU_ADJUS
Thread though is for Software Links, not Coding questions.
Hi Guys!
Nice to meet you all BMW lovers.
I have a F25 from 2015 too NBT I was trying to get the FSC using 1B file extractor without any success. Do you have any other methode? I also got the BMW AI Coder 5 but is full of viruses. :D
Shawn can I get last E-Sys and PZD please PM me.
Thank you!
One quick question, you know that have several version of E-sys software, if I for example want to install in the same computer windows 10 the version 3.27.1 and the version 3.30.1, I install the software in the folders for example "C:\EC-Apps\ESG\E-Sys3271\" and "C:\EC-Apps\ESG\E-Sys3301\", this is right and it's clear.
My question is about c:\Data folder, can use the same data folder with the 2 versions, or I need to make diferent data folder for each versions, for example use c:\Data3271 for version 3.27.1, and c:\Data3301 for the version 3.30.1, the question is for install diferents versions of e-sys need different data folder, or can use the 2 diferent versions of e-sys program with only one data folder? Thanks.
They will share same data folder c:\data. You set this in each installed E-Sys Options.
Hi Shawnsheridan - please could you pm me the latest links? Have been trying rather unsuccessfully to find all of the software myself for too long to put off asking for help.
Thanks in advance
PM sent.
