1,681 - 1,700 of 6,167 Posts
Hi,
One quick question, I makw coding last day with the car, I have all ecu cads in my computer, I saved it from original car, then now is possible make coding with this files, and after have all this files coded and modified upload all this file to the car and no soend time coding with the carn turned on or with a charger conected in car? Habe any tutorial or guide for make it? Thank a lot.
Enviado desde mi iPhone utilizando Tapatalk
Again, Wrong Thread. As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates not for Coding specifics. :dunno:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click ECU CAFD File => Select New FDL => Navigate to C:\ESysData\CAF and select matching .NCD file => Left-Click on Inserted CAFD => Select FDL Code.
Hello, I hope you're all well. Looking to get the latest E-sys, psdzdata, launcher and token generator if possible. Thanks in advance.
Hi shawnsheridan - I'd like access to the latest e-sys and psdzdata launcher/tokens as well. Looking to custom code my 2016 740i. Thanks a mill!
PM's sent.
Hey Shawnsheridan, is it possible for you to send me the latest E-Sys launcher/ token generator plus the psdzdata files? Back in the game and I would like to customize my F25
Thanks,
PM sent.
Hi Shawn,
Had to rebuild my laptop from scratch and thought I had a copy of ISTA but it turns out it was Esys, Dr Ginie etc and no ISTA
Is there anywhere this be pulled down from?
Thanks in advance.
Wrong Thread. Thread is for Coding software, not ISTA. PM sent.
Alright, so I'm a newb ... very excited to be here, but not sure I understand what I'm getting myself into. I have a 2016 740i M-Sport (G012) and I'm looking to code some minor things like M-animation on the iDrive screen, Alpina colors (not logo) on the instrument cluster, Angel Eye brightness and on w/ fogs, disable iDrive disclaimer/acceptance, close trunk lid w/ remote, and tire pressure/temperature readouts. I have a basic understanding of coding ... I can't write it, but I can usually read and modify existing code. So far, nothing I've researched about how to do this seems above my head. The problem is that there seem to be lots of tutorials, DIY videos, cheat sheets, etc for many bimmer chassis except mine ... the G012. The last thing I want to do is brick my module. Are there folks out there who have successfully coded a G12 who can share specific experiences on what worked and what didn't? Some basic questions I have ... can you code with the engine running? How much time should I set aside for this project? Is it possible to copy/download my existing code so that I can familiarize myself with it offline before attempting to write anything back to the module? What kind of mistakes can lead to bricking the module?
So far I've downloaded E-Sys and E-Sys Launcher Pro 2.8.1 as well as v.4.23.12_PSdZData_Lite. I'm expecting my ENET/OBD2 cable to be delivered today and the first thing I want to do is create a back-up of my existing code.
I'd love to hear from anyone who has experience specifically with G12s. Thanks in advance!
Wrong Thread! As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates, its for software requests only, not general coding questions. :(
I can't tell you what is possible in G12, as I never coded one. You can code all ECU with Motor Running, except DME /DDE. You can read all ECU Coding Data from Car, and then edit .NCD files offline, and then reconnect to car and write modified .NCD back to ECU(s). For Gxx car, you will most likely need E-SysX for the newer ECU CAFD Mapping, not Launcher PRO 2..8.1.
Ah! Thanks, Shawn. I'll move to a different thread.
