Cruise Control and High idle while A/C in on
6.4K views 13 replies 8 participants last post by  starnerBMW90
#1 ·
Hi everyone,
I am really new to this, so don't mind me. My problem consist of first of all my cruise control does not function at all anymore... and the other problem is my engine starts to rev while A/C is on and car is in park. I am not sure if these are related issues or if completely separate. Any help would be great. Some one PLEASE HELP!!!
Setup:
Stock 325I
Automatic
(I have made no changes)
#6 ·
Cruise control
It rises past 3000 RPM's as if I was just sitting on the gas pedal. And actually it was 60 degrees here today lol.... But I will definitely try your suggestions. I have the haynes manual and plan on tracing the wiring diagram to try every component. please keep helping me lol... ill keep everyone posted
#7 ·
im not sure what it is that makes the car idle higher once the A/C is engauged, but i would guess its that computer or whatever that is the issue
#12 ·
E30 high idle a/c
I fixed mine. It turned out to be the throttle position sensor. It had no continuity when the throttle was at idle. As such, the ECU did not engage the idle stabilizer to control the speed.
Pull the connector off and check continuity between the middle spade and the left spade. It should have continuity at idle. If not, it probably requires replacement. Only about $60
#13 ·
I have a 1990 BMW 325i i just got it a couple of days ago, and the first two days i was driving it fine, then IT HAPPEN when i go to stop at a light or stop sign and through it in neutral my RPM goes up and when i though it in first still stopped it goes down but it causes me to stall out....but then it will stop and be normal again but this has happen to me a couple of times now already and its embarrassing when i stall out at a light and have people yelling at me, so im having the same problems....
