removeing disc on rear nut allen key screw which holds disc on chewed any advice how to removed this to get my discs off thanks
EXACTLY! This is one of the few screws you can and should add antiseize lube to. And don't worry about it "falling off", cause it can't, the wheel won't let it even if it vibrates loose.Do NOT overtighten it; for some reason people thing this holds the rotor on. It's just a set screw to position the rotor.
Ya see! That's what you get when your 'torque meter arm' gets miscalibrated and carried away...This is why I ALWAYS pay the extra $5 for new retainer nuts when I do rotors.
