Driveshaft U joints
2 reading
6.2K views 8 replies 5 participants last post by  cn90
#1 ·
While in for an oil change at a local indy shop I was told there was some play the driveshaft u joint and while not that bad it will need to be replaced soon (when the car starts shaking while accelerating or highway speeds). I believe I was quoted a price under $700 for a reman.
I already had it replaced almost 5 years ago to the date - supposedly with a new one. I was told to call monday and see if there was any warranty - a long shot at best, but does anybody know if there is any warranty? I'm also thinking that the driveshaft should've lasted longer that 5 years. Do you think they charged me for a new one and installed a remanufactured one? I have read horror stories online if driveshafts giving out on the highway and something out with it like transmission pan.
Thx
#2 ·
I just replaced mine. If yours is '04-06 you have more options that I did; that said my custom shaft with easily replaceable joints is cheaper than your price.
Giubo, Carrier bearing and rear u joint
#3 ·
I’m curious why or how they said you needed a u joint? The entire shaft is hidden above a heat shield and not accessible without removal or manipulation.
I read in your other thread that yours is an earlier one; you can get a new replaceable u joint from Rockford Drivelines for $27 that uses c clip retainers on the inside faces of the shaft yoke. The joint is shared with the 7 series (I forget which chassis).
#4 ·
"I'm curious why or how they said you needed a u joint? The entire shaft is hidden above a heat shield and not accessible without removal or manipulation."
Maybe I'm not calling it right, but I can see it if I poke my head underneath the car. There is a little play in it
#7 ·
I just replaced mine with a Dorman one for around $175 on sale on Amazon. I think they are normally around $325 retail.
Turner/ECS sells a remanufactured front drive shaft for a little under $800. SO maybe inline with what your mechanic installed 5 years ago.
Jack up the front wheels and you can check for play. Likely the rear U joint by the transfers case, which was the case for me. Also look for that redish/brown dust that likes to form when U-joints start going bad. An easy DIY- no more than 1 hour taking your time.
#8 ·
I replaced my front drive shaft on my 2004 X3 back in June with a cheap (presumably Chinese) shaft from this site: 2004 BMW X3 Drive Shaft - BMW X3 Driveline - Free Shipping (wholesaleimportparts.com)
It was $172 w/shipping at the time but I bought the bolts separately. So far so good on the new one. The rearward u-joint on the old one abruptly dislodged at about 150K miles. It must have been failing silently for a while.
BMW advises to replace the output seal and drive flange on the transfer case whenever the front driveshaft is replaced. I haven't done that yet but I think it's a good idea. The way the u-joint failed and dislodged (and then knocked against the transmission) would have definitely stressed the output seal, but it's a wear item anyway.
Last month I also finally replaced the rear driveshaft because the center support bearing had been dry for a very long time. I went cheap again and put in RockAuto's "house brand" which comes from a variety of sources. The one I got looks like it's a Dorman but the slipjoint is a bit different and the collar doesn't lock like the OE version does. The quality of the giubo and center support bearing are fine, although I think the shaft itself is a bit heavier than the OE. But it works fine. At 150K it made sense to replace the assembly rather than just the bearing, and I might rebuild the old shaft at some point.
#9 ·
This (bad Rear U-Joint) has been discussed many times here before. I plan to work on the Rear DS soon.
My questions are mostly academic...
1. Can a bad DS with vibration at let's say 40-50 mph cause damage to the Rear Diff?
2. How about TC bearing?
Just wondering if the constant vibration causes damage to adjacent parts...
