Hi everyone,
I have a BMW F21 with EPS to replace, there is a missing CAFD so I tried to "Detect CAF for SWE" but when I try to code I have the following error message:
So i decided to flash it thinking that software was too old:
What I have done is:
From tal processing I loaded all the files.
Select only EPS
Start
Could anyone please help me to sort this out.
I am using ESYS 3.33.4 without any loader
Code:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
Read SVT before TAL execution started.
Read SVT before TAL execution finished.
ExecutionID=2020/06/20-18:31:31.547
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[EPS - 30] prepareECUforCoding started [PROGRESS]
[EPS - 30] prepareECUforCoding finished [PROGRESS]
[EPS - 30] authenticateECUforCoding started [PROGRESS]
[EPS - 30] authenticateECUforCoding finished [PROGRESS]
[EPS - 30 - cafd_00000694-003_003_046] Transaction type: cdDeploy; Message: TA started [TRANSACTION]
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=EPS_30_ETHERNET> [DIAGSERVICE]
[] job failed with negative response error:
code: repeat job
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: EPS_30_ETHERNET
severity: ERROR
[THROWABLE]
[EPS - 30 - cafd_00000694-003_003_046] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]
[EPS - 30] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
code: repeat job
severity: ERROR
[WARN]
[EPS - 30] - [Exception - EPS - 30] job failed with negative response error:
code: repeat job
severity: ERROR
code: repeat job
severity: ERROR
[THROWABLE]
[EPS - 30] There was an error during TAL execution, please check the log files. [WARN]
code: repeat job
severity: ERROR
[EPS - 30] finalizeECUCoding started [PROGRESS]
[EPS - 30] finalizeECUCoding finished [PROGRESS]
[] There was an error, please check the log files. [WARN]
[] - [Exception - EPS - 30] job failed with negative response error:
code: repeat job
severity: ERROR
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "4s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Abarbeitung beendet
- Read FA
- Read VCM or ECU (tried both)
- Calculate complete flash
- Save with and without HW-IDs from SVTactual
- Calculate TAL
Select only EPS
Start
Code:
ExecutionID=2020/06/20-18:38:47.423
code: repeat job
severity: ERROR
[THROWABLE]
code: repeat job
severity: ERROR
[WARN]
code: repeat job
severity: ERROR
code: repeat job
severity: ERROR
[THROWABLE]
code: repeat job
severity: ERROR
code: repeat job
severity: ERROR
TAL execution finished. Duration: "8s". [C206]
