F10 2010 6wa retrofit
2 reading
1.5K views 13 replies 4 participants last post by  BallyM
#1 ·
Hi All
I know this has been covered many times before but can’t work out what I’m doing wrong with changing my basic Kombi to 6wa with e-sys and enet cable so hoping a fellow members can assist
So I have flashed the Kombi with success but have the following issues
1) cruise control and speed limiter functions don’t work. Cruise control turns on but doesn’t allow to activate when driving
2) every time I turn off ignition and back on 3 miles get added to the mileage. Also red dot is there so seller obviously didn’t virginise. The original miles is 40k on the clock and my car is on 107k
3) tried to flash zgw but it failed and put my car in transport mode
For now I have put the original basic Kombi in which is working as normal including correct mileage, cruise control etc but hoping to get to the bottom of this with your help
Bally
#13 ·
HWEL is different. did you add 6WA to FA?
Did you replace ZGW with newer one since your car is 09/10?
