Status
Not open for further replies.
21 - 40 of 62 Posts
Can someone help me how to program my headlight, I replaced the module on ISTA, but need to program the module, thank you
Program whole car with ISTA+ or Flash module with E-Sys and PSdZData Full.
Save
did anyone here manage to solve the dreaded problem with there halos? I had the same problem as every other BMW owner. Replaced the whole headlight with a new one along with new module and Halo bulbs. Then used Protool (excellent software) to code the accent light and adaptive back onto the module which worked fine. but wont teach in the halos on my F10 lci. I am doing my nuts in trying to figure out possible solutions. The worst part is when I plug in the ISTA and run the teach in process it works perfect every function works as it should but when I unplug the OBD2 or turn ignition off then back on the module resets, an am back to square on. What am I doing wrong or any advice would be helpful
Apologies as I know this has been covered but I am really confused. I have a 14' 535i M. Recently I replaced the headlight control module on the driver's side due to water damage. Shawn provided me with the most recent Esys 3.30.1 and PSZDATA. I injected the latest I-level into the TMS which did not have a CAFD file and that headlight does now level and work in sync with the passenger side.
Shawn's instructions on a previous post.
"Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE"
The reason I replaced the headlight module was because the angel eyes and amber led marker were not working and after coding they are still not working. Am I missing something? I have searched and read for for weeks and the more I read the more I get confused. Some things to note
I checked all fuses and they are good
The headlight module is new and not used
Thank you in advance
Just wondering if I could get the software or tell me who you got it from?
Hi guys , just replace my original headlight with after markret from Alibaba everything is fine and all works the only thing is i have headlight vertical aim control fault , once i turn on the car i can see the lights moving and adjusting up and down but the manual volume next to the light control volume knob and i have this headlight aim control fault , jsut trying to totally remove or diactivate this madule but i cant find the exact madule name in Esys or ISTA. any idea what to look , unit name or code ????
Hi Shawn, I replaced both headlight with the modules it came with. It is used one. now I see only low beams work. Nothing else. Could you guide me to recode and then to code to make it work. Car 2015 bmw 435i f32. Please help
I have no guide for this. If you replaced any ECU's, you need to inject CAFD and VO Code it, and then initialize the lights in ISTA.
Save
Hi Shawn. I have the sĂ­milar problem: replaced TMS modules amd now vertical aim is all over the place. Passenger side DRL are not workimg.
When you say "inject CAFD" : which software are you referring to? E-Sys?
I own Bimmer Utility but think i need a newer E-Sys like 3.30 with the psdzdata full. All E-Sys I have found are full of viruses.
Can you tell me how to get a working E-Sys?
Yes, E-Sys. PM sent.
Save
Hi Shawn, My bmw car is 9 pin headlights. But the mechanic replaced with 8 pin. Do you think it can work. Also drl s sometimes turns on by itsrlf sbd then as we touch the car yo open it closes. The low beam only works. Can you please suggest. Thanks.
Sorry, I have no idea at all.
Save
Save
@shawnsheridan , you seem like a nice person helping a lot of newbs like myself out. Can you assist me in obtaining a virus free e-sys ( I have INSTA up and running) to help with exactly what everyone in this thread is going through?
Many thanks to you.
Cheers!
21 - 40 of 62 Posts
Status
You have insufficient privileges to reply here.
