Hi all,
Here is the situation:
1. Right-rear suspension airbag regularly deflates from normal ride-height upon starting the car ignition (accessory), or just unlocking and opening the door, ie. waking the car up from sleep.
2. Starting the engine may inflate the airbag to its normal ride height, but not always.
3. No errors in the car, or in ISTA-D during either of these two scenarios.
4. Manual inflation and deflation is successful using INPA/ISTA-D.
5. Turning off Transport Mode often re-inflates the airbag (but not always).
6. As soon as the engine is stopped, it may deflate again, but not always.
7. If it doesn’t deflate, it can remain inflated for days on end until the car is “awoken” again or the engine started.
8. Compressor relay checked for correct operation – opened the case and applied 12v and the relay “clicks” as it should do.
9. Solenoid valve replaced with original Wabco part.
10. Tested every component of the “integrated suspension” using ISTA-D, activating components where possible and reading out the modules successfully, such as ride-height sensors.
11. Problem still occurs.
Given this scenario, I am at a loss as to what the problem could be. I can deduce that:
1. The airbag has no puncture (otherwise it wouldn’t stay up when parked in some cases).
2. The relay is not faulty (the relay is for the operation of the compressor, which activates when required).
3. The solenoid is working fine – changed to a brand new one.
4. There is no part that it is completely faulty, either some or all of the time (otherwise there would be a fault logged for loss of connectivity of power).
The only part that I think may be causing this is the “discharge valve” on the compressor – does anyone know anything about this? Otherwise, it may be a software logic issue?
The other thing is that I think perhaps the ride-height is missing for this side of the suspension, and only inflates to a "safe" or "transport" height when engine started. However, my version of ISTA/INPA gives an unknown error when inputting and the measurements. Has anyone done this before successfully, and if so, can they point me to the right location to get the same version?
Very desperate!
Very desperate!
