401 - 420 of 738 Posts
Hello, please help
I was coding kafas2 but I had a fault during coding transmition
Now there are not any CAFD in the ecu kafas2 and I cannot do any coding
How can install a cafd?
Please help!!
Hello,
Activating "FA" is the same.
Then, it reads the "SVT" file that has been backed up.
Right-click "KAFAS2" to initialize the code.
Would you revive this way?
Does anyone have a 5AT/5AR loaded F48 they are willing to share their CAFD/SVT with me. I'm trying to work out why I can't get TJA to work on mine and hoping a CAFD/SVT comparison will show the differences! I have ACC and all the bits fitted, coded and working but TJA refuses to operate (error message "Traffic Jam Assistant cannot be activated"). Message changes when on non-motorway roads. Steering button works and the steering wheel has the touch sensor fitted. Is there a calibration missing I wonder? Any help would be hugely appreciated. Mike
Hello.
Would you like to compare with my F39 5AR retrofit "TJA" CAFD? I'll send my Gmail address later.
Hi!
I drive a LCI f46
is it possible to code for
1) unlock all doors when car boot is opened
2) trigger side mirrors to fold when the "lock" button is pressed when closing the boot?
Hi bregan,
2) ...
FEM_BODY or BDC_BODY> KOMFORT_SCHLIESSEN
Default: Werte = 0F (1.5 seconds)
Setting value: Werte = 00 (0 seconds)
Hello,
Can anyone help me with enabling fog lights as cornering lights? I have F54 and LED fog lamps. I tried F30 guide to do that, but it did not work.
Hi funkier,
When I read the German comment on the BDC_BODY light part with "NCD / CAFD Tool", it was written that function 09 is left cornering light and function 0A is right cornering light.
Note!: The following are untested predictions.
BDC_BODY > 3063 LceLampMapping2, C3 >
MAPPING_NEBELSCHW_L/R_FUNCTION = 09/0A (Default: 08 = Fog Light)
(L/R = L or R , 09/0A = 09 or 0A)
add to-------
MAPPING_NEBELSCHW_L_FUNCTION = 09 (Default: 08 = Fog Light)
MAPPING_NEBELSCHW_R_FUNCTION = 0A (Default: 08 = Fog Light)
If I'm wrong ... I'm sorry ...
P.S.
Enabling cornering lights will probably not work as fog lights.
F54 Mini Clubman Coding
Hi,
i've already coded some functions with bimmercode in my clubman F54 (like enhanced bluetooth for sms readings and dual phone connection, stop/start memory, and some others), and want more :)
1. is it possible to code SLI without FSC code?
2. is it possible to code ACC? Mini, as i know, is using only front camera without additional sensors
3. is it possible to code LDW?
4. Can i add fsc with Bimmercode (it has FSC menu in HU_NBT section)?
Hi,
Assuming car has KAFAS module, SLI must have an FSC Code but LDW can be simply coded.
I have no idea if ACC can be coded or not. It does not require an FSC Code, so it just a matter of having the hardware.
I can't comment on Bimmercode. I don't use it myself.
Hi,
ACC requires SAS module and kafas. Yes you can code it. I would vo code it but I suppose it's possible to fdl code.
Shawn how do I get FSC for sli?
Hi forum. I have finished adding quite a few bits to my F48 (5AR, 5AT, 6NW, dimming mirrors, pedestrian alert etc). Everything works but I have one error left in head unit on ISTA. Refuses to go even with reset unit, clearing fault memory and reverting head unit to base as per VO. Error code is B7F8E4 with "DIAGCODE : D6510_HU_000000_90_901. ISTA test plan not helpful nor description. Driving me nuts. Anyone out there have any pointers or can tell me what the DIAGCODE means. Stumped!!! Thanks.
