481 - 500 of 738 Posts
Hi,
I retrofitted Traffic Jam Assist at F39.
(#400)
At that time, I thought 5AT was essential. . .
My friend F45 is a 5AS equipped car that is not a 5AT.
We recently implemented a 5DF retrofit. Today we are retrofitting Traffic Jam Assist (5AR & Quidzel HOD Emulator).
5AR (Quidzel HOD Emulator) can operate on a car equipped with 5AS + 5DF.
https://youtu.be/ceYTR-WuI20
P.S.
"5AS + 5DF" is almost the same as 5AT.
Do you think this would also work on Mini F54?
It can be operated with BMW (F48, F39, F45, F46, F15, i3) equipped with 5AT (or 5AS + 5DF retrofit), and I think it does not work with MINI.
( I think 5AR (Traffic Jam Assist) option doesn't exist in MINI. )
P.S.
Cornering lights still not solved?
P.S.
Cornering lights still not solved. I gave up on that already.
How about stop and go type of ACC in Mini? Do you have experience on that?
I have no experience with MINI ACC (541?). My F39 ACC is 5DF (Active Cruise Ctrl + stop & go Funct.).
I am fiddled with the following settings.
ACC maximum speed: 140 -> 180 km/h
SAS> 3000 FAS, FC> LDM_Wunschgeschw_ACC_max_kmh = wert180 (24) (default: Wert140 (1C))
OPTIONS (wert130 = 1A, wert180 = 24, Wert140 = 1C)
ACC & DCC minimum speed: 30 -> 5 km/h
SAS> 3000 FAS, FC> LDM_Wunschgeschw_min_kmh = 05 (default: wert30 (1E))
OPTIONS (wert30 = 1E)
P.S.
Cornering light has been PM since the other day. Are you not reading it? I think we can solve it.
HELP !!!
I drive a G30 5 series In India. And few months back I had purchased Apple car play from an online website and installed it.
Now yesterday my car went to the dealership and they tried to update the software or something. They were successfully able to update everything except the navigation and the dealership told me they since I had purchased the car play from a 3 party seller that the navigation software has been currupted and not working now on my car. Navigation is not getting activated on my car at all... can you please help how to get back my navigation ...
Hello everyone,
I am planning to retrofit a HUD to my mini.
I do not want to rip apart all of the dash but instead cut from above with a master.
For those with dash-cutting experience or ones who replaced a HUD: Do you think I can fit the HUD through an opening slightly larger than the original but still smaller than the plastic bracket so that the cut is still hidden by the plastic bracket?
For everyone: What do you think about cutting the dash from top, without ripping apart anything?
Hello everyone,
Hi all,
i'm approaching to the coding world. I've an F20 on i successfully code some cheat but now i'd like to code something more on my father's F45 2014 218i AT.
Especially he asck me for voice control that I understood that require a FSC code to get proper coded.
Can anyone provide me an FSC code?
a part of this i've to add the 6NS code in FA
1) Just Add 6NS to FA and VO Code HU_ENTRYNAV
2) You will not get Voice Control without an FSC Code, but you can still code EBT.
3) No. Just add 6NS to FA, Save FA, Load FA in Coding Module, Activate FA, and VO Code HU_ENTRYNAV. -> where i've to insert and activate the FSC code?
Thaks
Massimo
Hi all,
Massimo
Yes, you need a C7 Voice Control FSC Code. PM sent.
About coding sport auto transmission to F55
Hi all!
My vehicle is 2016 MINI Cooper S F55 with regular steering wheel(no paddle shifters) and auto transmission
I came to this thread to find what exactly needs to be coded in E-Sys to get 2TB Sport Transmission, launch control and possibly enable paddle shifters in case I decide to add them in the future.
I downloaded E-Sys 3.27.1, Launcher Pro 2.8... and PSDzData lite v4.21... - will this be compatible with what I want to do? I have never used this software before.
Hi all!
On MINI COOPER S F55, does anyone know exactly which items get coded with the addition of 2TB option?
You do not need to be asking same thing in multiple places:
https://f30.bimmerpost.com/forums/showthread.php?p=26006974#post26006974
