581 - 600 of 738 Posts
Thank you - I will give this a try later
UPDATE
The front fog lights only come on with the Welcome Lights if the light switch is set to headlights. On the 0 automatic light setting the fog lights don't light up.
I coded the TPMS to display pressure & temp but this doesn't work and the pressures have to be reset every time the car is started #annoying . I have coded it back to tyre pressure only.
Hi,
I have coded SLI in my F46 some months ago, bought an FSC code and was working for months.
After a campaing for check egr the dealer updated the software to ilevel 21/03.
The FSC was not there but I was able to cert again and now when read FSCs is there, so is ok.
I made all steps again but I can’t get the BC button to show it, not even the —- —- , is simply not in the loop. Its activated on iDrive but no way.
I tried 2 or 3 times to do everything again without luck.
Any advice on what to try?
this is what I did months ago and what I was trying now:
At last, I finish my retrofit halogen to Led Light test connection and coding on F46.
Only left to install everything nicely. :eek:)
Hey man, can you tell me is there any repinning or adding wires that need to be done? I’ve just bought full-LED headlights for my F48, and planing to install them instead of the halogen ones. You should totally make a tutorial or make a detailed post with step-by-step instructions. There are many of us trying to figure out the same issue.
Thank you man!
DIY Guide - Retrofitting cruise control on F45/F46
Finally solved my problem and completed cruise control coding. Knowing that information on F45 and F46 is limited on the web I have prepared a DIY Guide for those who want to install the dynamic cruise control on their F45/F46.
Here is the link:
Dropbox - Error
5 years later, I know, but can you upload this document again please?
Hi
I don't know if my rear camera is damaged (3AG)
I have seen TRSVC in ISTA+ , what is the name of ecu in e-sys svt , PMA2?
Because I bought a camera module (same part number) that has already been used, I want to reset it
Help ,Any suggestions for reset
F46,
I-Stap F056-15-11-503
ICAM2 is your camera module, If you install a new or second hand part, remember to inject cafd and vo code ICAM2.
Hi Maaii
Thanks for your reply !
I`m simulated from the last saved file (VO & SVT)
I have a question, inject cafd to ICAM2(use detect CAF and select the same I-step shipment)
The ICAM2 tree is all black
When I click HW-IDs from SVTactual the ICAM2 tree folder have red/blue
I don't know where the difference
Or did I understand the operation incorrectly?
Hi Maaii
You can see difference in svt-editor.
Enviado desde mi SM-G988B mediante Tapatalk
Question: I am using Bimmercode for my F45 and it seems (in expert mode) comparable with FDL coding by E-sys. But a lot more user friendly! I know in Bimmercode you cannot do VO coding, but are the FDL coding options indeed the same?
Ok, scratch LDW out, since the vibrating steering wheel is an expensive component. For ACC it is stated in the service manual that the F48 has no Distance Sensor and utilizes only the KAFAS camera module. There are also no dash control buttons since everything is being setup through iDrive. Since the breaking function and camera are already there I cannot see what else is missing...
I want to do the same thing: did you manage to get 5DF working?
