161 - 180 of 738 Posts
Hi,
About the coding below:
HU_NBT_EVO
HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, HUD_SPORTANZEIGE_MS_GASSE_ENABLE
KOMBI
HUD_FAHRSTUFE_ENABLE
On my car I already do this and work perfectly.
But, today I try to do the same coding to another mini 2014 and didn't work. I change the same parameters but I unable to activate the sport his on the idrive.
Any idea?
His car: F56_16_03_502 - 2014
Tks!!!
Sato.
I have one question, would those codes for MINI JCW HUD work with a F45 HUD? Has anyone tried?
My target is F56_16_03_504 and HUD looks exactly the same.
Hello Folks,
I just retrofitted the reversing camera to my F54.
The picture quality of the camera is perfect, is the original model, but the line guides are unaligned and uncalibrated.
Can some one tell me how to calibrate it ?
I retrofitted and VO (3AG added) coded PMA2, NBT , and NBT , any more is needed?
Regards.
Hello Everybody,
I'm new in this forum and thanks in advance for your attention.
I've got a BMW Serie 2 Gran Tourer since October 2015 (BMW F46-2015 218D) :
+ It is a Luxury Pack (ZY3)
+ Navigation Professional (6UP) & 610(HUD) with iDrive Touch
+5AV : Active guard ,incl. SLI and Approach control warning => The KAFAS2 camera is included
+3AG Rear Camera
I bought an ODBII-ENET cable from eBay :
Everything is fine with this car except that I want to code my car in order to get the following additional features :
+ 6NS : Enhanced Bluetooth & Connectivity => VO coding or FDL Coding on specific ECU function ? I don't think we need FSC code here... If VO Coding, could you give me the EXACT procedure in order to avoid mistakes (it is my first experience by coding on a BMW car ! :dunno::)
+ C7 : Voice Control associated with 6NS option; I have to get the FSC Code to activate this specific Voice Command Feature :
1) How to get this FSC Code ? shawnsheridan could you PM me on this please ?
2) How to insert this FSC code via the E-Sys Software ? What is the EXACT procedure ?
3) What is the EXACT procedure to do the FDL or VO Coding in order to get this Voice Control Feature ?
+ 8TH (Speed Limit Info) & 8TF (Active pedestrian protection) & 5AD (Lane departure warning); I have to get the FSC Code to activate these features (8TH/8TF/5AD):
3) What is the EXACT procedure to do the FDL or VO Coding in order to get these 8TH/8TF/5AD safety features ?
Thanks in advance for your precious help !:thumbup::D
CoolPhil972
Hello Everybody,
+3AG Rear Camera
CoolPhil972
For EBT:
http://www.bimmerfest.com/forums/showpost.php?p=8020396&postcount=7
For C7 and 7E FSC Codes, PM sent.
6ns features
Hi, I have coded successfully 6ns in my F48 (I can see "Office" in the CID).
I find the following issues odd:
- I can pair an additional phone and for example choose to stream music from it while using the "primary" phone for calls. I noticed that if the second phone rings, the call is not transferred to the car (nothing shows in the display, no sound in the loudspeaker). Is that normal?
- And another thing, when displaying a text message in the CID, I can choose reply (actually forward) but I can not write a message with the iDrive controller. Is that correct?
After enabling 6ns, I get the following fault code (with ISTA+):
B7F850 Microphone 2. Open circuit
I guess it detects that the 2. microphone does not exist. Has anybody got the same fault code after coding 6NS? Nobody has mentioned that before (or at least I haven't run into it...)
...After enabling 6ns, I get the following fault code (with ISTA+):
The fault code for missing 2nd microphone is well documented. Most people just use 6NS for VO Coding, not actually write 6NS to FA, so when car goes in for Service, if won't be an issue if Programming with ISTA/P is performed.
You can also FDL Code out the error:
HU_NBT => MICROPHONE_NUMBER = wert_01
I will do the correction with the FDL coding. I am still under warranty, I don't want to let them get into any stupid ideas...
Does anybody know if the wiring for the 2nd microphone is already pre-installed? Would be nice to just buy and plug the 2nd mic :D
If I don't FDL code out the error, can I re-write my original FA WITHOUT coding the HU and solve the issue?
If original FA is stored in car, then dealer programming will work without issue.
E60 530i 2004 won't start good battery & starter was checked replaced key &ignition switch any advise wld be appreciated
Sent from my SAMSUNG-SM-G928A using Tapatalk
Alternator?
