Content moved to separate threads
Fxx, Ixx, & Gxx Series Coding:
Why do you think Flashing ECU will fix it?Hello. I have no lights on my license plate. On Ista-D the Frm ecu is green on device tree. Is there a way I can re-flash frm ecu with e-sys? Would this help me getting license plate lights again? Thanks.
Enviado do meu ONE A2003 através de Tapatalk
Scroll up one post.Shawn. I think I will get onto the coding train. Can you please PM me the instructions and software? Thanks in advance![]()
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
TAL execution started.
ExecutionID=2016/07/19-19:25:05.805
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_NBT - 63] prepareECUforCoding started
[HU_NBT - 63] prepareECUforCoding finished
[HU_NBT - 63] authenticateECUforCoding started
[HU_NBT - 63] authenticateECUforCoding finished
[HU_NBT - 63 - cafd_00000ded-003_013_025] Transaction type: cdDeploy; Message: TA started
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=HU_NBT_63_ETHERNET>
[HU_NBT - 63 - cafd_00000ded-003_013_025] Transaction type: cdDeploy; Message: TA finished
[HU_NBT - 63] There was an error during TAL execution, please check the log files.
[HU_NBT - 63] - [Exception - HU_NBT - 63] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT_63_ETHERNET
severity: ERROR
[HU_NBT - 63] finalizeECUCoding started
[HU_NBT - 63] finalizeECUCoding finished
[] There was an error, please check the log files.
[] - [Exception - HU_NBT - 63] job failed with negative response error:
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "20s". [C206]
Abarbeitung beendet
Known issue with Launcher and HKFM_LS. Inject CAFD:There are no CAFD files in the HKFM folder. I'm not sure if they were there until I went to enable close trunk from fob after doing some other coding (below) and taking a break. Did I delete something by accident?
The trunk will not go up now. It unlocks from FOB and dash button, but will not open at all or close with buttons in trunk.
PM sent.... If its not too much trouble to include the instructions as if I were a first time installer I will read through them all to verify I have everything correct.
Thank you so much again.
-Joe
PM sent.New to the forum and my first BMW, I just bought the ENET cable.
Can you please be linked to software and psdzdata files
Thank you in advance
- Kevin
PM sent.Hi,
Also just got the cable for coding 2015 Bmw I8. Can anyone send me info? Thanks!!!
What happens when you try "Read ECU?"So I have a lead and all the software.
I thought I had loaded it all correctly.
Gone to test and got as far as pressing the 'read SVT' button and got the following message:
This is on my F56 Mini (my car not the wifes, not brave enough to try it on her 4 day old car just yet! F48 X1)
Any help on how to progress?
Windows 10 is fine. PM sent.Hi Shawn,
can you please send me the latest psz files and the E-sys with the token? I will change some things in my i3. Does it work with windows 10?
Thank you
