This is more a curiosity question . . .
Back in 2012 (~25,000 miles) when the vehicle was relatively new I compared the indicated mpg on the dash versus the old fashioned method of fill-up to fill-up distance traveled calculations . . . I was very impressed to see the two figures within a tenth of an mpg of each other . . . yes, it was repeatable . . . never saw a difference greater than 0.5 mpg.
The mpg in 2012 was around 23 mpg and it held steady for nearly 100,000 miles.
Then around the summer of 2017 (~110,000 miles), I noticed the indicated mpg had dropped to 19 mpg . . . reset the mpg meter several times and every single time to this day (~151,000 miles) it is pretty much 19 mpg. I can't remember if I did a manual mpg calculation . . .
Now, for a different reason, I started to record the gallons consumed and odometer at fillup . . . a few more keystrokes on the phone and I can get the mpg . . .
Guess what . . . mpg is now back up to ~23 mpg . . . and this has been consistent for the past five or six fill-ups . . .
My guess now is - the actual/real mpg never dropped and it was just the incorrect indicated mpg.
I don't know how the system is measuring the fuel consumed and converting it into mpg . . . there is the mpg "needle" that is very sensitive to how hard you push on the accelerator . . . and then there is the digital display . . . which also is somewhat sensitive . . . you can clearly see it getting updated after a reset . . .
Not sure how the system keeps track of say the fuel consumed for the past 500 miles (approx. matches the manual mpg calculation).
Even less clear what may have changed that causes this longer window mpg error . . . doubt there is a physical problem with one or more sensors as there are zero fault codes of any sort other than the advisory 0452A. Also, the manual mpg calculation is still showing the mpg the car had when it was new . . . so logic says this has to be a computing error . . . not sure how that is possible.
Sure would be nice to know how this discrepancy can be explained . . . anyone?
