Having a M52, M52TU, and M54? I can say without reservation that take the intake off, learn the details about the CCV, throttle body, boots, intake vac lines, and just absorb it all. At first it is a daunting task but in the end you will be intimate with your power plant. Also, can’t beat getting those hard pipes replaced with proper clean out and o ring seat. I used RTV for lube on the rings, some say don’t, some say do, up to you.
Helps a LOT to have the Bentley, forum archives, and FCP/real.OEM.
Get yourself a smoke machine too. My ‘03 e46 ran like crap until I got a proper smoke machine and found all of the O rings that needed attention. Smoked my M20 and M52 after and they are both tight. Nothing like a solid smoke maker like the Stinger I got.
My M54 E46 has 260,000 miles on it. I did the hard pipes at 200,000K miles. They did not leak but broke apart when I touched them during the replacement. Also, the intake and valve cover gaskets were breaking at the touch and would not have survived re-installation. Went ahead and did those, coils, plugs, boots, CCV, idle control pipe, TB gasket, OEM MAF, air filter, DISA, cleaned fuel injectors, fuel filter, fuel pump, fuel lines/clamps/rubber, steering guibo, on and on......you get the idea. Entire cooling system including radiator too.
Doing the radiator on the M52 E39 this week, always something but always a lifetime warranty on these things with FCP. No worries.
