help, RPM problem...
1 reading
804 views 2 replies 3 participants last post by  jonathan2263
#1 ·
The car has good idle, no rough. but when i press on acceslerator slowly and equally RPM increases and when it reaches about 1500 rpm the tachometer stops increasing rpm although i continue press on acceslerator pedal, any ideas? i've replaced oxygen sensors, spark plugs, oil fuel and air filters, replaced Cranckcase ventilation system and hoses, maybe MAF? ICV? or Vanos?
see link to youtube
#2 ·
First things first....you need to go get the codes scanned. The results from that will point you in the right direction.
