Radio wire harness disconnect issue
11K views 7 replies 6 participants last post by  z3JamesBond
#1 · (Edited)
I have a 97 Z3. I'm having trouble disconnecting the wiring harness from the radio. The image on the cover for the wire harnesses says to pop it up. It goes up about a quarter inch and stops.
What do I do from here?
The Bentley book offers no guidance on this.
Any help would be greatly appreciated, thanks in advance.
#2 · (Edited)
You have to slide something to allow it to disconnect...
"... The stock cable harness uses a multi-lead connector with a slide locking mechanism. To detach the connector from the old radio, slide the locking mechanism to the side and then the connector lifts off the back of the radio."
http://www.eabjr.com/Business-Radio-C33-and-CD43.php
"... you need to remove the harness from the back of the cd unit. This is a bit tricky. As the diagram on the harness shows (see two pictures down, with the blue wire tap), put a screw driver in the top to loosen it. If yours is easy, it will then slide right up, and you can remove the harness. Most take some monekying, though. I had to flip it over and press on either side of the plastic bracket with a screw driver, alternating sides, in order to slowly jimmy it loose."
http://www.davidparis.org/coupe/hktp.html
#8 ·
What Zeeboy said above worked!! I just upgraded my radio and the same exact problem happened to me. The harness moves up above an inch and just seems to be completely stuck, and I pulled and yank as much as I could, doesn't budge. Until! I stick a wrench / screwdriver from back to front (kinda like stabbing myself), with the screwdriver tip pointing to the middle of the radio, and just lifted the handle and the thing came right off.
