Re-Initialize Steering Tilt BMW F10 535
1 reading
3.9K views 3 replies 3 participants last post by  Pstephana
#1 ·
I have a 2011 535xi that the steering tilt and telescoping functions stopped working. There is no clicking or any noise whatsoever when it is told to move.
Similar problem in this thread:
http://www.bimmerfest.com/forums/showpost.php?p=9790618&postcount=13
Solution in above post was to clear the fault code and Re-Initialize the steering tilt/control. This post said they took it to someone that connected a computer and it was fixed by Re-Initialization. (I am not sure if this was INPA or ECS Tuning or ???
does anyone know the procedure to do this steering Re-Initialization? (I have seen some posts about correcting the steering angle but that (I believe) is making the steering wheel straight when the car is going straight.
#2 ·
I haven't done it, but I'd be willing to bet that's an ista function, rather than inpa or ecs. That's what I used to reinitialize my seats.
When you connect to ista, it will probably prompt you to calibrate it anyway.
#4 ·
Hello.
Were you able to resolve th steering tilt issue? I have a 2011 F10, checked all the fuses (glove and trunk) all were fine. I was even thinking of double checking the fuses again in the glove area just for piece of mind.
Thanks.
