SCARY: Car JERKS, Traction Control (DSC) light flickers, stays on
27K views 7 replies 5 participants last post by  bimmerboy93
#1 ·
Had the crap scared out of me today. Was driving on the highway (75mph) when I felt a jerk, the car swerved (almost as if I had a flat tire), and my DSC light came on.
I've been recently having a DSC issue (for the past three days) where the DSC light flickers, then stays on and doesn't go off until I turn off the car. After I turn the car on, the light is off, but after some driving, comes back on.
What happens every single time it comes back on is I can feel some sort of "jerk" or impedance to movement of the car. Once the light stays on, there are no more problems.
I read over 8 pages of posts and the WIKI. I have NO other lights on--just the DSC. When I turn off the DSC manually, the car drives fine. I had alignment done about 6 weeks ago.
i have a 2000 323Cic with 92,000 miles on it. 5MT.
#2 ·
Probably a bad wheel-speed sensor (there are 4 of them).
#3 ·
I will look into it, as I gathered from the other posts. My concern is the jerk--seems something might be wrong mechanically, unless it's the limited rear slip diff coming on. Any thoughts?
Also, I cannot for my life find the part number of the wheel-speed sensor, on RealOem.com or PelicanParts. Is it the same thing as ABS rotational sensor?
#4 ·
Part of the function of the DSC is to direct more or less braking force to one particular wheel in a hard, fast turn....a bad sensor could possibly cause one brake to be applied heavily at the wrong time, causing a swerving condition. Only "M" cars have limited slip diffs...all others use a manipulation of the ABS/DSC system.
#5 ·
+1 top Bob's advice. Another possible culprit is a low battery. All kinds of wierd things can happen. Go have the free test done at an auto parts store, can't hurt.
#6 ·
im with fast bob on this one. a wheel speed sensor going wacky makes the most since. you should have a dtc in the dsc computer if that is the case. i don't know of any aftermarket scanners that can communicate with dsc module. may have to get a dealer scanner hooked up to it.
#7 ·
Many thanks guys. Will check my battery at Autozone and then take off the wheels and clean sensors when I change the oil. For some reason, the DSC issue went away recently...will post update on how things go.
#8 ·
Please help!! I have a 02 325i with a 112,000 miles just got it a week ago an my abs light brake light engine light an traction control lights stay on constantly no weird jerks or anything just annoys me to death I do need brakes so that could be the reason for the brake light an my engine light says my cars running to lean so I took it to a local shop an was told to replace my pcv An CCv system and my valve cover but I'm still puzzled about my abs and traction control lights ;(! Love love the car it's beautiful and I want to keep it. Please help!!
