Sevice engine soon
693 views 1 reply 2 participants last post by  banglenot
#1 ·
Does anyone know how to reset the "Sevice engine soon" light on the dash, I recently changed out the alternator and overlooked plugging in the MAF sensor and it set off the service engine soon light, I herd you can reset it without a code reader but can reset it from the dash just like the Sevice resets, any help would be appreciated.
#2 ·
If the fault that caused it is corrected, it'll reset itself after a certain number of post-fix start cycles. If you have a code reader (like INPA), you can see if its a permanent code or a transient one, now that you fixed the problem that caused it. Also, INPA can clear the codes and reset it.
