121 - 140 of 148 Posts
Sticky Steering-Z4 2006 3.0si
I bought a complete steering column for a Z4 2008, 3.0si. After I received it I took it to a European Garage. They looked at the steering and said they couldn't satisfactorily install it since they did not put in"a Locking Key" before its removal. He told me to return it. My question is are they right that it can not be satisfactorily installed. Please advise
Please start your own thread with this question. This entire section is ONLY for DIY items. Not questions.
This reply and you question will both be removed soon.
This thread is meant to be Z4-specific. Post links and how-to's as replies to this thread. I/we will edit as needed.
This thread is NOT for questions. This thread is to post DIY or How-To's. If you have a question about your car, please start a new thread. Do NOT post your question here. Your post will be deleted in the interest of keeping this thread on topic.
If you have a question about a DIY posted here, feel free to ask away here or int he original thread.
I check my fuse for continuity and found out fuse # 32 had OL (open loop)
Fuse is good, that mean somewhere in the wire had broken.
It relate to engine.
Anyone know how or where to look for power drain on this fuse # 32 wire diagram?
Sent from my SM-P600 using Bimmerfest mobile app
Ship Killer's top motor replacement guides, guide on replacing the lift cylinders, and my DIY on relocating the pump motor to the trunk..........
Added drain cleaning instruction.
Added instruction for replacing top canvas without removing top assembly from car.
Soft top related: An easy way to reinsert 4 plastic clips that hold the rooftop stowage shelf.
I've been struggling with it myself and found that the easiest way to put them back in is from inside the car. When the roof is up you could observe the shelf behind the seats.
1. First, make sure from inside the trunk that the wires holding the shelf in place on both sides are firmly positioned inside the edges of the shelf in all four spots that require clips.
2. Make sure that the shelf is positioned properly in respect to the microswitch in the middle: test whether you can open/close the rooftop from panel controls.
3. Then, inside the car from behind the seats slide all four clips into their spots - effortlessly. You will feel a faint click when a clip is seated. That works for me but there could be a better way.
