I'm having trouble removing 3 of my 6 plugs. I'm scared to turn it too hard in fear I may snap one off. What's the best way to get these plugs out ?
That's interesting.the oil in the anti seize bake's off, then leaves a nice concrete like paste
The TIS (from my spark plug DIY thread) says not to use anything:Bentley manual states "lightly lubricate new spark plug threads with copper-based anti-seize compound".
Yup. This is from my spark plug DIY above:the NGK (oem plugs) website gives the opposite advice, stating their plating process negates the need for anti-seize and lubrication risks over tightening.
I used the gray anti-seize, but I didn't know about the baking effect at the time. Sigh.Me? I figure BMW made the cars, and took NGKs advice to heart, yet still felt anti-seize is necessary. So I use a bit of copper anti-seize,
Now you tell me.I can tell you with 100% certainty that anti seize is not designed for high heat applications. The oil in the base heats up.. bakes out, and leave a concrete like paste which is just about as good as lock tight
It is just the way you wrote your post. I read it like you were directly responding to the OP who should be long past this problem now.and..................?
Did I miss something here? I thought Bentley was a third party with no affiliation to BMW and they personally recommend using anti-seize while BMW recommended against it in the first place so how could they "still recommend using" on newer cars?Bentley manual states "lightly lubricate new spark plug threads with copper-based anti-seize compound". But the NGK (oem plugs) website gives the opposite advice, stating their plating process negates the need for anti-seize and lubrication risks over tightening.
Would anyone know if the newer BMWs (which I assume still have a long replacement interval) still recommend using anti-seize?
This is a canonical thread, which simply means it was referenced in the bestlinks, when someone looks for how to remove stuck plugs.It is just the way you wrote your post. I read it like you were directly responding to the OP who should be long past this problem now.
no that was directed at you, for making the comment about it being a old post,It is just the way you wrote your post. I read it like you were directly responding to the OP who should be long past this problem now.
I guess, in cases where it's glopped on, it could...Had some very good mechanics tell me the use of anti seize on plugs would cause a misfire
Interesting video on why "not" to use anti-seize with our spark plugs. https://www.youtube.com/watch?v=sjeGqWBGh-A
Interesting.
They used good instrumentation to conclude that the DIS (distributorless ignition system) spark was shorting along the side of the spark plug and arcing to the long arm of the J gap, because excess anti-seize compound plugged the gap.
This, they say, was causing the fuel:air mixture to explode when the intake valve was still open.
They saw the visual arc along the plug from the 35,000 volts. They surmised that in a distributor system, the arcing occurs at the distributor. Here it was arcing down the side of the spark plug, leaving a burn mark where it hit the steel shell, and the ceramic is cracked.
Due to contamination of the spark plug gap, the arc on one side created carbon hot spots on the other side.
Presumably the hot spots were causing the backfire.
They concluded that a "little" anti-seize is ok, but all three spark plug manufacturers don't recommend it (as we knew), but, for four reasons (some of which are counter intuitive).
First, they explained how anti-seize works, in that they said the metal particles embedded in the grease sacrifice themselves instead of the spark plug metal, but, the grease itself causes:
a) Torque wrench issues
b) Which results in damage to the spark plug due to what they called 'stretched threads'
c) And, strangely enough, they said it might make the spark plug even HARDER to take out (due to what they called "jammed threads")
d) And, more importantly, squeezed out grease can cause, they say, contamination of the spark plug gap
I found the explanation a bit far off that the grease can cause "jamming" of the threads, but I did get the main point of how it can "pump" excess anti-seize into the chamber onto the business end of the spark plugs.
Interesting, they also said the grease that comes with the spark plug boot does three things:
1. Makes the boot easier to remove years later
2. Fills the air gap between boot and ceramic ribs to prevent arcing
3. Helps the boot fit into the ribs of the ceramic (huh?)
I agree with you that they were "pushing" their case a bit too far.Interesting vid. IMO, the engineer uses a bit of spin to make his case
