What differential fluid do you use in your E39? (Brand? Weight? Synthetic or mineral?, Where do you get it? API?, SAE?)
What differential do you have? How often do you replace it? How much fluid do you use?
I'm trying to fill out a single-page chart of the dozen fluids used in the E39 but I'm all confused since the differential is not covered in the Bentleys.
Some E39s are limited slip while most are not; yet the Bentleys make no distinction; yet Castrol does (see below).
The Bentleys say it's a lifetime oil while Castrol says BWM recommends bi-annual replacement.
The Bentleys don't say the SAE viscosity nor the API quality classification yet the Castrol site provides multiple SAE viscosities in the API GL-5 hypoid gear oil category.
Here's my latest summary for the E39 (as always, please correct as needed):
- Differential (conventional, i.e., non-limited-slip E39s): The Bentleys specify "BMW SAF-XO synthetic final drive gear oil" which doesn't exist (it's Castrol). The Bentleys don't specify the weight (it's SAE 75W-90); and the Bentleys don't specify the quality (it's API GL-5 hypoid gear oil). Given that, suitable replacements are Amsoil Synthetic Manual Transmission Fluid (MTF) API 75W90,Mobil1, Royal Purple Max-Gear, & Redline SAE 75W90 API GL-5 synthetic gear oils. Unfortunately, there's no way to tell which of the three (3) different differentials you have w/o looking at the numbers molded into the metal. Bentley page 020-11 & 020-26 & 331-6. [Volume: Type G=1.7 quarts, Type 188 Compact=1.1 quarts, Type 220/215 Compact=1.5 quarts.] Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles).
- Differential (limited-slip E39s, such as the M5): BMW SAF-XJ API GL-5 SAE 75W-140 synthetic hypoid final-drive gear oil (aka Castrol SAF-XJ). This requirement is not listed in the Bentley manual; it is gleaned from the Castrol literature and from what is stated about the M5 in this thread below (please correct if necessary). Replacement Interval: Lifetime fluid (but most recommend replacing differential fluid at the same time you replace transmission fluid, which is about 5 years or roughly 60K miles).
CONFUSING REFERENCES:
- Castrol marketing PDF
- For the people who use OEM manual trans fluid
- Recommendations closest to Castrol SAF-XO 75w-90?
- Transmission Fluid Castrol SAF-X0
- Castrol SAF-XO 75w-90 Synthetic Final Drive Lubricant
- Final Drive Viscosity?
- Pelican BMW 3-series limited slip differential swap
