Here are the parts that needed for the mod. I ordered them though Summit Racing.
1- SUM-G4904 - Electric Fan, Single, 16 in. Diameter, Reversible, 2,010 cfm, Black, Plastic, Each $84.95
- I went with this because it's a curved fan which will lower the noise level, and I'm very please with the outcome, also it is reversible for puller or pusher type of use.
2- DER-16749 - Fan Control, Thermostatic, Adjustable, 150 to 240 Degrees, Kit $39.95
- I picked this because temperature setting to activate the fan is adjustable.
3- ATM-2283 - Radiator Hose Adapter, Aluminum, 1.5 in. to 1.5 in., Kit $37.95
- Aluminum and they are the only place that I can find to carry 3/8 NPT port.
I also bough a new fan shroud, so I can take my time working without hurrying.
I went to work at it, to begin I cut the top porting of the shroud to make it even. Here are some pix.
