Dear All,
Greetings from Estonia!
Its been 6 years since qurrent topic, but let me answer to the unanswered question: Where the heck solar sensor is connected and how?
Sensor goes directly into IHKA panel, main blue connector X610.
Sensor is hard to get out, due to the reason, that it goes out between airtunnel connection and is attached with doublesided tape. From its connector, sendor is extended into X610 connector.
AND the pin assignment is as follow:
X610 Pin14- Power
X610 Pin15- Left sensor signal
X610 Pin16- Right sensor signal
X610 Pin19- Ground
The reason I struggled with this, is that machine is from year 99 and swapped IHKA is from year 2000.
So basically solar sensor was added starting from facelift models and up.
Many owners, who swapped this panel, to new (2000 &up) have'nt maybe noticed difference in climate control work, but if to scan the system, it shows solar sensor R and L error.
So this was the reason, why I digged into this matter.
Installed solar sensor and started to search, where to stick it.
No answer around the world forums, but huh. it took some time to dig this out.
All the best and cheers,
Viljar
