2,901 - 2,920 of 6,169 Posts
Hello,
I have problem of airbag blinking light after ACSM ecu upgraded. It seem I need eDiaBase Tools with lastest ACSM5.prg,
Where can I found it please ?
PM sent.
So I hooked up Esys to my F40 for the first time. Managed to connect successfully. I followed the normal coding process that I've done for my F22 but it seems some things were different. I was searching for 2 items; ASD and VIM..Trying to achieve sporty setting in ASD menu and VIM. However the folders didn't have the name, just numbers so im not sure where to look for my settings to change. Is this some sort of mapping missing ? Screenshots below:
1028480
1028481
Am I doings something wrong? Am I looking in the wrong place?
Any advise will be very much appreciated!
PM sent.
  • Like
Reactions: wo66
Hi shawn, i have the 2018 x5 with drivers assistance package, not the plus. it does not stop the car in case of traffic jam, just gives me a visual warning on the hud, my question , is there way way to have it warn me sooner and with sound warning too? Thanks much
Looks like your same post on Bimmerpost was answered:
Hi all,
I'm back after several years of absence, with a Mini Countryman F60 my 2019.
I coded the car when I bought it, but now I would like to modify some things that seem to no longer work as before after an update in BMW.
I tried to do something but I have a problem probably due to old psdzdata (4.27.31). Where can I find the latest?
Anyway, the error occurs when I try to read coding data on any ecu, for example this one comes from ACSM2 CAFD_000011AB_007_003_010 Fehler:
File for "cafd_000011ab_007_003_010" not found! [C012]
thanks and best
Luca
Ok, good luck with it.
Hi all,
thanks and best
Luca
PM sent.
Hello everybody
Ok, now I can read, but not write :(Anyone have any ideas?
E-Sys 3.28.1 and 3.30.1
PSdZData 4.28.41
Launcher Pro 2.8.1.155
You need to expand "Ausgelesen", and then you can edit the FDL Code:"
