761 - 780 of 6,160 Posts
Discussion starter · #761 ·
Even with administrator did not work. I had a problem with windows. I created a new user and it worked.
Thanks for the answer
:thumbup:
Alternatively, you can move data folder to somewhere else without restriction.
For F-series programming; I've installed INSTA+ which I understand we use for Diag and Prog but do we need ICOM setup to program fully or can I used ENET Cable with ICOM configured in INSTA? Is that the ICOM "emulator"?? or is the ICOM settings in INST+ just for a true ICOM setup??
No, emulator will not work. ENET is fine for diagnostics, but an actual ICOM is needed for flash programming.
:thumbup:
Any recommendations? There are wide variety of them and they vary greatly in price..... Thanks!
Hello!
I can neither read the FSC codes, nor check their status. (See attach)
I use latest Launcher Pro, E-Sys 3.33.0(b. 536400) x64 and PSdZData Lite 4.14.14.
A week ago, the car was updated at the dealer.
Current i-level 18-11-523
FDL coding work fine.
What could be causing the error?
Hello!
There is no error. You are checking Specifically for FSC Code AppID 323, which is CarPlay, and your Head Unit does not have this FSC Code.
I know that I check CarPlay.
Before updating, I had a working CarPlay. After the update, it does not work.
Can I get a list of FSC codes statuses?
Or is it necessary to do a check for each AppId?
You can use E-Sys => Comfort Mode => FSC => Check FSC Status with just Diagnostic Address 0x63, and leave Blank the AppID, and you will see all Head Unit FSC Codes.
But, just because you have working CarPlay, does not mean you have AppID 323 (143) FSC Code. 6CP CarPlay from factory is a Subscription Service, enabled via Telematic Provisioning, not FSC Code.
Thank You!
Look at the PM please.
Thank You!
I replied to your PM. For your VIN, your services including Apple CarPlay and ConnectedDrive Services, are Locked, which you will need to take up with BMW AG:
Hi guys
Can i get a link to the Launcher Pro
Thanks for help
Requesting Launcher PRO 3.x is useless. It won't work without an Activation Code, same as old E-Sys Launcher 2.x, and the only way to get an Activation Code is to generate one using his WebApp, which requires a Access/Code Login from TokenMaster. Anyone wanting Launcher PRO needs to just email TokenMaster (fxxtokenmaster@gmail.com) and get setup by him. There is nothing anyone else can do for you.
Thanks for the information
Hi all
i am new here and i bought a US version F56 JCW and shipped the car abroad
the radio frequency and the sat nav is not working properly in my area i called my local service
and they said the car need to be reprogrammed to your local area
is it possible to do this through coding and ESYS ?
if YES please send me all i need
thank you
Hi all
thank you
Yes. See Post # 1.
shawn
can you please help me get the right cable for my F56 JCW 2016 !
and the right software please
Any $20 ENET cable off eBay or Amazon should work fine.
Software Links are in Post # 1.
thanyu can you please tell me howe can i pay for full version esys
I assume you are referring to Launcher PRO. Only way is to get from developer TokenMaster himself (fxxtokenmaster@gmail.com)
