1,661 - 1,680 of 6,165 Posts
Thank you.
I have a problem with coding my kombi control unit. It only shows trimmed function.
All others are working without problems. Whats the problem? :cry:
The KOMBI CAFD is not mapped. What is CAFD Name, and what Launcher version are you using?
Hi Shaw,
I coding a F series and all right. Then change to a G series and get this error, why? I have installed the last pszdata and the car is from 5/2019.
Any solutions?
Enviado desde mi iPhone utilizando Tapatalk
Use Read ECU instead of Read SVT.
Only this? And why this pass in G series? Thanks
It's best for all cars, but a must for car's with BDC.
Hi again Shaw,
Maybe a stupid question, but I have a doubt, I use last pszdata when I start E-sys before connect to my car, is a F20, then the e-sys shows 4 F20 conections, which I need to select:
F020_19_11_538_V_004_005_000
or
F020_20_03_540_V_004_002_000
Please what I need to choose?
In other main series have the same problem, have 2 options... and I don't know which option choose.
I know that NEVER will be select the DIRECT option.
Hi again Shaw,
or
The newer (bottom) one.
CAFD name is "CAFD_00003C3B_001_006_077".
I am using the Launcher version 2.8.1.155.
cafd_00003c3b.caf.001_006_077 is trimmed with Launcher 2.8.1.
It is mapped in both Launcher PRO 3.7 and E-SysX.
Hello everybody.
I have Led Headlight modul for BMW 4-series and i want convert to BMW 3-series. Could you tell me what i must do first to do coding? I have software E-SYS 3.27.1 and ISTA+.
Wrong Thread. As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates not for Coding specifics.
Install ECU, Inject CAFD, and VO Code ECU. If that fails, you will need to Flash it.
Hello Shawn, I am a G30 owner who is new to coding, could you please send me E-sys, psdzdata, launcher and token generator?
Many Thanks!
PM sent.
Hi,
One quick question, I makw coding last day with the car, I have all ecu cads in my computer, I saved it from original car, then now is possible make coding with this files, and after have all this files coded and modified upload all this file to the car and no soend time coding with the carn turned on or with a charger conected in car? Habe any tutorial or guide for make it? Thank a lot.
